R27 oil dipstick diameter?
Begonnen von † Will, 13 Oktober 2013, 00:21:41
† Will
Hello,
I have a problem with the oil level dipstick on my R27. The dipstick does not screw in to the crankcase - it just drops in without holding. The dipstick from my R25/3 does not fit either.
My question is - are the dipsticks for the R25 a smaller thread diameter than the thread on an R27 oil level dipstick?
I notice that the oil pump slotted tops are a different size to each other with the R27 (Vin No. 380533) being larger.
Many thanks if you can assist.
† Will
The diameter for the Oil dipsticks are the same....for the oil pump differs ....at the end of 52 the gets larger
Hi Will,
the thread should measure: 26 x 1,5 mm
For both R25/3 and R27.
† Will
Thank you for the information Rolf.
Zitat von: Rütz am 13 Oktober 2013, 18:32:22
Hi Will,
Thank you for the measurements Rutz. The threads on the dipstick are completely stripped off and I need a new one. I hope the thread in the crankcase is good enough. Now I have an accurate measurement I can check it tomorrow.
The "fully restored"  :o machine has many faults and is not as good as it first appeared to be.
