regler connection
Begonnen von fidel_98_99, 22 August 2012, 22:03:09
fidel_98_99
I am restoring a bmwR26 and i bought a new regler from ebay.
I want to connect it but my knowledge at electrics is not so good
the regler came with this plan :
Uploaded with ImageShack.us
How to connect 1,2,3?
help
a diagramm or pictures would help
Thanks in advance
fidel_98_99
Hi fidel,
There's no need to connect anything to the points marked 1,2, and 3 in your diagram. This is all inside your generator housing and you will just have to locate the cables running from the generator to your new electronic regulator ('Regler').
At point (1, *), you'll need to locate the resistor (R) and insulate it from the ground. This is most likely the yellow cable in the upper left (top) corner of the generator housing. Please refer to the lower (written) part of the instructions supplied by the manufacturer of the regulator. Here's another recent thread with some pictures illustrating how to locate the resistor (cable):
http://bmw-einzylinder.de/forum/index.php?topic=10341.msg138093#msg138093
As for the other cables, I have used a slightly modified routing for the same regulator. Please refer to this diagram I have sketched in another thread:
http://bmw-einzylinder.de/forum/index.php?topic=9850.msg131160#msg131160
Hope this helps,
fidel_98_99
