Clutch assymbly
Begonnen von opus, 20 Mai 2006, 19:46:48
opus
Hello
I am trying to put together my clutch.The bike is a BMW R 25/3.  What must I do
opus
Dave
Allo Opus,
A good start would be the R26 manual here at Einzylinder (Start > Tips > Handbuecher >  INSTANDSETZUNGSANLEITUNG R26 & R27Deutsch / English / Italiano / Francais [13 Mb]).
I **THINK** the clutches are same / similar and this manual is well illustrated.
Dave.
Jesper Mikkelsen
Hello.
I have not parted the clutch. I have just taken the rear part off,and now it will not fit together. Must the clutch plates be tigthend or ?
Jesper
Garnet Grylls
Jesper
You will need to use 3 long blots with a nut on them to start to pull the clutch together before the stock bolts will start.
Run the nuts all the way up the long bolts and thread them in by hand into every other hole. Tighten the nuts down one turn at a time till the friction plate is compressed enough to start the short bolts that held the clutch together originaly. Then remove the long bolts and replace with the last 3 short bolts and tighten them all down evenly.
Garnet
