BMW R25/2/3
Begonnen von angusbuchananbmw, 29 September 2024, 10:43:51
angusbuchananbmw
Hi all
l have a BMW R25/3 frame fitted with R25/2 forks and an R25 engine.I am not sure what exhaust pipe i would need for this.Can anyone advise me please as i see that different exhausts are listed for each model.
Regards Ken
R25/3, R26 and R27
angusbuchananbmw
R25/3, R26 and R27
Hello there,
the point is that R25 engine is fitted without dampers in engine case and exhaust can be fitted on left frame tube where the engine bolt is fitted. R25/3 engine is fitted with dampers front and rear and exhaust is mounted on a bracket at lower gearbox bolts. So the complete system can shake. the exhaust on 25/3 is 30 mm, on R25 36mm. If you want to put on the R25 engine on  25/3 frame you have to use the distance washer on left side of the frame and exhaust 36mm has to be used.
Or you put on the 25/3 bracket on lower gear box bolts with R26 (36mm) exhaust clamp.
Will say, you have to mix a little bit but it works.
you should also check what cylinder head is on your engine.
see
https://www.bmw-einzylinder.de/Vergleichstabelle/default.html
if it is an R25/3 head you need the 30mm pipe rather than the 36mm
Hello Ken.
Basically, the cylinder head of the engine installed will tell you which exhaust system you will need (diameter of the exit hole), please refer to Hubi's link (it should default to English on your computer, as the page will look for the browser's langauge preferences).
This will also determine which silencer you can use, again pipe diameter being the pivotal point.
On the other hand, as your frame doesn't align with the exhaust system, you will have to do some thinking on how to attach the pipe and the silencer to the frame...let your inner engineer off the leash ;D
If you need help with any specific pounting points, please provide some pictures so we can assess the situation.
Kind regards, Taz
