Front shock absorbers
Begonnen von BSA Bob, 15 September 2023, 06:11:41
BSA Bob
One of the front shock absorbers on the R26 is leaking & will need replacement.
Meanwhile, I have a set from a twin that I can fit. I assume these will be a bit stiffer, but has anyone had serious problems doing this?
BSA Bob
Hello Bob,
the shock absorbers of the twins are the same as in a single in my memory. Compare the numbers of the absorbers. Only the springs are different.
in fact....they are different....BUT....I had no problems with taking them for single...the difference is too little
Rolf is correct. Took a look in the auxiliary catalog and saw that the numbers are different.
BSA Bob
Thanks for the reassurance, folks.
