BMW R4 frame number
Begonnen von CLAUDE, 18 Dezember 2022, 18:31:47
CLAUDE
Hello,
On my french paper I have the number A 33746.
I'm looking for a number on the frame.
On the rear right side I find nothing.
May be it's another place for it ? Iff you have an idea ?
I haven't plate on the front off the frame.
A picture off my research :
CLAUDE
Kurt in S.A.
Check left side near the axle.  Is 33746 for the R4?  Could it be for an R12?
Kurt
Kurt in S.A.
CLAUDE
Thank you Kurt.
I'll do it  ;)
CLAUDE
Another questions :
Is the R4 fr
CLAUDE
Bonjour,
Est ce que le cadre R4 est le même que le R12 ?
Où peut-on le trouver sur une R12 ?
Merci pour vos réponses
CLAUDE
I'm always trying to indentify my bike.
Do you know wher I can find the frame number ?
cwf
I hope this appears big enough to help
Hi, factory positin of the number is at the red position. Replacement frames can also have the numbers at the blue marked positions.
BR Tino
Maybe this is a reading error because the numbers are illegible.
mike25-3
bei meiner R4S4 ist die Rahmennummer links auf dem waagerechten U-Profil unter der Achslagerung etwas Richtung vorne
Machen was geht, solange es geht ;-)
CLAUDE
Merci pour ces renseignements, je vais gratter la peinture  :pouces vers le haut:
