R2 Parts
Begonnen von David Grenfell, 19 Oktober 2022, 13:02:14
David Grenfell
Hello,
I am the lucky owner of a 1934 BMW R2/4 which I purchased as a 'barn-find'. Bringing it back to life is a slow process as I require some difficult to obtain parts.
Push-rod and oil-return sealing rubbers
Final drive oil-seal (between bevel-drive housing and rear hub)
Right hand side foot plate.
Any help would be appreciated.
David
David Grenfell
Hello David.
Right hand side footplate see https://emw-oldtimer.de/Trittbrett-rechts-Aluminium-BMW-R2-1-R2-2-R2-3-R2-4-R2-5
Ringing them up or sending an email regarding the other parts you'd be searching for wouldn't hurt...maybe they have not listed used parts somewhere in the back of the shed or could at least made aware of you searching, so in case they come across any of these they can give you a shout...
Good luck, Ute
David Grenfell
Good luck, Ute
Hello Ute,
Thanks for the link. They definately have some of the parts I need.
I will most probably need them again as I try and get the machine back on the road.
