reverse polarity
Begonnen von Jollyjester, 15 September 2021, 10:52:18
Jollyjester
 In my foolishness, age related, not reading the instruction, in a  rush, or not wearing my specs, I managed to fit the 6 v wet battery the wrong way round, with + positive earth.
It should be - Negative Earth, started the engine and the charge light did NOT go out, of course. so I feel sure I must have reversed the currant ??
Not an thing I recall in the past, and believe this is rectified by a brief bridge wire / connection /spark , between 2 terminals, without the engine running ??
Yes / No ???
and then, which ones are they, In the generator housing?
there is, 61, 51, 30, 31. Battery + is 30
Battery 31 - Neg earth.
Any instructions welcome
P.S. I have ordered a Panasonic Sealed Battery
Jollyjester
B+ to D+....or
30 to 61....engine running ....for 1-3 seconds
Jollyjester
Thanks so much, try later today, That is with the Battery connected correctly
31 - to earth
30 + to Lima
Jollyjester
If I may?
do I disconnect / remove 30 & 61 prior to the bridge ?
robert
on which bridge?...they are normally not connected....no...only connect with a cable
Jollyjester
sorry , by bridge I ment linking 30  & 61 together with an extra  wire
So, remove 1 or both cables ??
then (bridge  / link ) as you said
what will you remove?
take a cable and connect 30 and 61....finish!
but only for a very short time (~1 sec)!
and let's hope that your (electronic?) regulator is still ok
Was just about to say that.... typically reverse current kills the (electronic) regulator... good luck!
The elecromechanical F and Z regulators tolerate the procedure AND you don't need a wire, just close the "Rückstromkontakt" with  a finger ;D
... but his R25 has obviously an electronical regulator:
Have a Zofia 6v electronic unit. 10 years now, works perfectly, and 'WILL' start the engine if the battery is flat, or as in my case once., years ago, disconnected
