R26 silencer mounting
Begonnen von BSA Bob, 16 April 2021, 02:01:29
BSA Bob
When fitting the R26 silencer, should the mounting tab on the silencer be fitted inboard or outboard of the mounting lug on the frame?
Pictures show both.
I think my silencer is original. It was bought from Peter Ondrak in about 1977.
BSA Bob
isettawin
look here
BSA Bob
Thanks for the prompt replies folks. I'm pleased to see you say it's inboard. Based on pictures, I did a loose assembly with the tab mounted outboard & the silencer stuck out at a most undignified angle. But plenty of R26s seem to have it that way....
same thing. Most are wrong. Correct is inside, too.
Thanks, that was new for me
