Work is finnished.
Begonnen von Pederkr, 13 September 2020, 12:34:25
Pederkr
Then I'm satisfied.
3 1/2 years of renovation with missing results is finally over. It has been quite a task. Listed here.
1. Piston torn new bore.
2. Carburetor worn renovated.
3. Ignition defective changed to Vape
4. Flywheel torn loose on the crank.
5.New chain and tightener.
6.New crankshaft connecting rod not original 3 m / m for short.
7. New oil pump
8. New bearings in engine and gearbox.
9. Renovated rocker on the exhaust side
Adjusted sprocket on camshaft sprockets not aligned
11. New spring and breather.
Now run it like a new no noticeable noise. So next season there should be miles on the clock.
I am very happy for your help along the way.
https://www.youtube.com/watch?v=kvCXf0Z9Mcg&feature=youtu.be
:juhuu: :juhuu: :juhuu: :juhuu:
Pederkr
Dappsull
Muecke01
Congrats ! :applaus:
Nice work, well done.
Friedhelm
That is the idle sound we are looking for...
Enjoy,
