Cylinder head issue
Begonnen von Pederkr, 12 August 2020, 15:12:55
Pederkr
Some one who can tell me the messeurement on this grove by default. How deep it goes down.
Mine is no more than 3 m/m have a suspect that the fire ring is touching-
Pederkr
Hej Peder,
measurements taken from a NOS-R27-Head.
Hope this helps.
Vær hilset,
Hi Peder,
why not just checking it against the height of your fire ring (taking approx. 0.8 mm for the head gasket in account)?
Pederkr
Zitat von: 4Taktix am 12 August 2020, 15:51:12
Thanks Sascha it did help. I'm i trobule.  ::)
Got to mill out 0,4 m/m
Hej Peder,
Hope this helps.
Vær hilset,
Pederkr
Zitat von: Borgward am 12 August 2020, 16:02:52
It's a tight fit, just clear
Thanks for the advice  :schrauber:
Hi Peder,
Dappsull
why nor clean it a bit ;^) - will gain quite some spacing
Hi.
That's a common question.
The easiest way to find out about enough room there ... clean thoroughly, make sure that the head can be put on the cylinder and be turned freely there (like on a pivot)...if the gasket areas of head and cylinder are connecting then all's well, if not, measure and if you don't want to mill down the collar (fire ring) maybe a thicker head gasket will do the trick ...
Kind regards, Taz
Pederkr
sure, this is a before picture  ;)
Pederkr
Sure it's a before picture  ;)
Pederkr
Zitat von: Taz am 13 August 2020, 11:04:11
Hi.
Kind regards, Taz
I try to put som chalk (klay) (kridt) on the fire ring to make it possible to see if it touch the cylinder head. No marks, as i can messure i have 0.3 m/m clearence before fitting the gasket I think it´s all right.  :thumbsup:
