Tacho kackt
Begonnen von Dappsull, 17 April 2018, 14:41:30
Dappsull
erst heute bemerkt: das Protokoll von meiner letzten TUeV-Pruefung. Da brauche ich schon aus hygienischen Gruenden einen neuen Tacho
Dappsull
Stell dich nicht so an und mach ne Pampers drum ... tsetsetse ...
 :lol:
Also mein Tacho is stubenrein
krauthahn
Ein Tacho ist auch nur ein Mensch !
heinz leichtfuss
sicher kein Mangel!
Ansonsten check this:
Tacho Poop Color Chart
Similar to adults, your tacho's poop color, form and texture is a great way to understand what's going on in his or her digestive tract from top to bottom.
tacho poop color green black
Greeny black
This dark, tarry poop is called meconium. It consists of amniotic fluid, secretions of the intestinal glands, bile pigments, fatty acids, and intrauterine debris. Here's more information on green poop.
tacho poop color mustard yellowMustard Yellow
If you are exclusively breastfeeding, and your tacho's poop is bright or mustard yellow (and sometimes a slight orangish), congratulations, your tacho poop is normal.
tacho poop color tanTan
If your tacho is on formula, and their tacho poop is tan and slightly solid (think a thin peanut sauce), then it's normal.
tacho poop color lime greenLime Green
This tacho poop color usually means there is some digestive distress. One reason for green poop is a foremilk/hindmilk imbalance. That means tacho is not getting enough of the rich creamy milk at the end of a feed and, consequently, getting too much of the liquidy foremilk that is higher in lactose and lower in fat. This usually happens if you have too fast a letdown or oversupply and eventually will normalize in most cases. Making sure tacho finishes one side before offering the other will often fix this problem.
