R27 engine mount length
Begonnen von Jambo, 06 Januar 2018, 03:08:35
Jambo
Hello all,
I was mounting my R27 motor in the frame tonight and I realized that the engine mounts I have might not be the right length. They came NOS individually bagged (new 25 years ago) with the motorcycle when I bought it. The new ones measure 40mm long and it looks like the originals measure 42.5mm. But I cannot be sure of any of that because I did not remove the motor from the frame, nor did I purchase the new ones.
Can anyone help me with the correct length?
The project is coming down to the last parts and I will send pictures when I am done!!
Thanks!!!
James
Jambo
Dappsull
Are you referring to the silent blocks?
Jambo
yes, the two that mount the front of the motor to the frame and the two that go under the gearbox to the frame.
Thank you!
Dappsull
In my case it's 40 mm between the outer sides of the hex bits (an old, used mount I just measured)
Cheers
D.
Jambo
