R26 Restoration by new member from Australia login
Autor Thema: R26 Restoration by new member from Australia  (Gelesen 18808 mal)
grahamjb
  • Hobby-Schrauber
  • I love BMW-Einzylinder
    • 6062
    • Perth
    • Western Australia
    • Australia
    Years
« am: 01 Oktober 2017, 06:42:07 »
Hi Guys
I have been reading through this forum and hopefully will be able to share my 1958 R26 restoration when I work out how to post images.
My R26 has been rebuilt before, has some dodgy frame repairs and is worn out so it will be a learning curve for me to restore it back to good working condition.
Is there any information on this forum on shock absorber rebuilding and frame dimensions?
Thanks
Graham
bwprice100
  • Profi-Schrauber
    • SA8 3
    • Swansea
    • Neath Port Talbot
    • Wales
Re: R26 Restoration by new member from Australia
« Antwort #1 am: 01 Oktober 2017, 08:02:38 »
Hi Graham and welcome.
Looking forward to hearing your story.
I am just completing the rebuild of my R26 but I don't have any frame dimensions.
When you ask about suspension do you mean the damper cartridge?
Brian
Sent by me using tapety talky
grahamjb
  • Hobby-Schrauber
    • 6062
    • Perth
    • Western Australia
    • Australia
    Years
« Antwort #2 am: 01 Oktober 2017, 08:26:43 »
Gidday Brian
Thank you for the welcome and your restoration is excellent, you must be pretty pleased with how your bike looks, you have done a fantastic job.
In answer to your question, yes, I was referring to the damper cartridge. Mine have leaked most of he oil out and I am hoping that there is a repair/rebuild kit available or a list of seals that can be used.
Cheers
Graham
bwprice100
  • Profi-Schrauber
    • SA8 3
    • Swansea
    • Neath Port Talbot
    • Wales
« Antwort #3 am: 01 Oktober 2017, 09:40:20 »
I  did attempt rebuilding my dampers but gave up and bought some new ones as the rods were badly pitted. I have read that some people have had some success though.
  • Meister-Schrauber
    • Bayern
« Antwort #4 am: 01 Oktober 2017, 10:07:59 »
Hi Graham,
a warm welcome to down under!
posting pictures isn't that difficult:
* just click on "Anhänge und andere Optionen" (attachments and other options) below the text entry field
* then click on the button "Durchsuchen"(browse) below "Datei anhängen" and select the file with the picture you want to upload
* if you want to upload more than 1 picture (up to 6 are allowed ) just click on "mehr Dateianhänge" (more attachments) and proceed as before
note:
- the maximum size per file/picture is 1Mb
- all files uploaded to this forum must have a unique name; i.e. your upload will not be accepted if the filename already exists here.
cheers from Bavaria
    • 44319
    • Dortmund
    • NRW
« Antwort #5 am: 01 Oktober 2017, 12:11:15 »
Graham,
if I remember right you can add pictures to your messages after you have written more than 4 or 5 posts.
  • Global Moderator
  • Online
  • BMW R25/0
    • 63065
    • Offenbach
    • Hessen
« Antwort #6 am: 01 Oktober 2017, 12:28:47 »
* just click on "Anhänge und andere Optionen" (attachments and other options) below the text entry field [...]
Welcome to our forum, Graham  :applaus:
In case you want to change the forum-language (navigation-bars, buttons, ...) to "english", please click on "PROFIL" (upper navigation bar), then on "BENUTZERKONTO" (left navigation bar).
You will see a title "BEVORZUGTE SPRACHE" (preferred language). Click on the dropdown-menu and choose "ENGLISH".
Kind regards,
bwprice100
  • Profi-Schrauber
    • SA8 3
    • Swansea
    • Neath Port Talbot
    • Wales
« Antwort #7 am: 01 Oktober 2017, 14:34:44 »
Graham I stole this from another forum.
Hello David and all,
        I have a R26 and have resotered all 4 shocks.
The top is a threaded "plug" that acts as the top and gasket holder all in one, once you unscrew the top you can pull out all the insides, wash and inspect them. You will find one conical spring above the piston and one cyclindrical spring below it. At the bottom end of the inside tube you will find a valve with a conical spring on top and a cylindrical spring below. All conical springs are identical. Two sizes of cylindrical springs. I had to have all of these springs made for me, I could not find them at any shop. I also had the main springs made for the front shocks. The sealing "O" rings and top gasket I bought at a industrial gasket shop (common off the shelf items). One of the pistons was cracked, I had a new one made by a machinist (lathe operator). I purchased shock absorber liquid, filled them and closed them.  The 4 shock absorbers work perfectly. Please not that the bike will not be raced nor driven wildly cross-country, it will be looked after. I live in Argentina and tu purchase any spares or new parts out of the country is usually prohibitivly expensive (as was the case of new shocks or cartriges), we earn low salaries and also a disvantageous exchange rate. so in Argentina it is relatively easy to find someone that can make spare parts at a very reasanable price. Make sure you put new rubber "bumpers" on the rod between the top holder and the cartrige so the piston will not hit the valve a the bottom when the shock is "bottomed out".
If you or any one is interrested in more about this re-doing, just let me know.
Cheers
Geoffrey
Argentina.
grahamjb
  • Hobby-Schrauber
    • 6062
    • Perth
    • Western Australia
    • Australia
    Years
« Antwort #8 am: 02 Oktober 2017, 03:59:11 »
Thank you to all who have welcomed me to this forum and advised how to upload photos, it is appreciated  :)
Brian, can you please PM or email me with the contact details for Geoffrey in Argentina.
Can someone please advise if the steering friction damper bracket should be at the angle shown or should it line up with the centre line of the frame - see photo below.
I have also attached a couple of photos showing the poor welding frame repair found hidden under body filler near where the kick starter rubber attaches to the frame.
  • ommmmmh
« Antwort #9 am: 02 Oktober 2017, 09:51:37 »
in line....both brackets
grahamjb
  • Hobby-Schrauber
    • 6062
    • Perth
    • Western Australia
    • Australia
    Years
« Antwort #10 am: 02 Oktober 2017, 10:40:26 »
Thanks Rolf, being in line makes good engineering sense
Cheers
Graham
  • Meister-Schrauber
    • Bayern
« Antwort #11 am: 02 Oktober 2017, 10:53:46 »
w.r.t. the poor welding:
it's a kind of rated break point  ;D caused by the kick starter and /or the main stand. There are several approaches for a professional repair desribed in this forum. (keyword: "Rahmenbruch")  :schrauber:
cheers
    • Köln
« Antwort #12 am: 02 Oktober 2017, 18:08:07 »
G`Day Graham,
welcome to the forum of the Dags.  ;)
I`ll think you are the first member from Australia.  :prost:
Now we need an antarctic forumsmember an the long way around is completed.
Bye
    • 45525
    • Hattingen/Ruhr
    • NRW
« Antwort #13 am: 02 Oktober 2017, 19:37:43 »
Graham,
a warm welcome here.
Anyway does anybody know what is with Kiwi-Kai from New-Zealand?
« Letzte Änderung: 02 Oktober 2017, 22:12:47 von Heiko »
  • ommmmmh
« Antwort #14 am: 02 Oktober 2017, 20:45:55 »
No...leider...der war mal bei mir vor geraumer Zeit...dann noch PM's....dann Funkstille
grahamjb
  • Hobby-Schrauber
    • 6062
    • Perth
    • Western Australia
    • Australia
    Years
« Antwort #15 am: 03 Oktober 2017, 04:27:50 »
Hubi - that makes sense because the frame has been squashed where the kick start rubber is fastened to the frame. I am having trouble finding any post that shows the preferred repair and will file down the welding and fill the squashed section of the frame with some bronze.
Heiko - Google tells me that Kiwi-Kai is a food store in New Zealand, does that answer your question?
Rolf - I don't fully understand your post and google translator doesn't make any sense.
Cheers
Graham
  • BMW Z3 und R26
    • Nähe Ulm
    • Baden-Württemberg
    YearsYearsYears
« Antwort #16 am: 03 Oktober 2017, 09:44:56 »
Hey Graham, a warm welcome in this outstanding international community!
Here is a link describing the "pipe-in-pipe" method:
Sascha's repair
and here the method inserting some flat iron is described:
Krauthahn's repair
search-term in google: "rahmenbruch site:bmw-einzylinder.de"
My big respect that you will rework it and not just replace. Good luck, a lot of fun and keep it up!
with best regards,
Steffen
  • Meister-Schrauber
    • Bayern
« Antwort #17 am: 03 Oktober 2017, 10:28:49 »
and here is another approach by cutting off and replacing a small piece (45mm) of the frame:
http://bmw-einzylinder.de/forum/index.php?topic=8724.msg114075#msg114033
grahamjb
  • Hobby-Schrauber
    • 6062
    • Perth
    • Western Australia
    • Australia
    Years
« Antwort #18 am: 03 Oktober 2017, 10:57:20 »
Thanks for the frame repair links OldsCool! and Borgward; it seems that these frames suffer from metal fatigue especially around where the engine mounting bolts go through the frame. I will examine my frame carefully and strengthen/repair if required. Luckily I have pretty good welding skills from restoring Vintage cars so it should not be a difficult job to do  :)
Where is the best place to buy restoration parts from such as bearings, frame rubbers, gaskets, engine and gearbox parts etc?
Thanks
Graham
    • 45525
    • Hattingen/Ruhr
    • NRW
« Antwort #19 am: 03 Oktober 2017, 13:06:42 »
Kiwi–Kai normally is a member of this Forum over 15 years now. He visited Rolf a few years ago but he wasnˋt present her after his journey to Gemany when i remember well.
Anyway glad to have a member here from Down Under now.  ;)
  • ommmmmh
« Antwort #20 am: 03 Oktober 2017, 13:13:58 »
That was the translation of my threat ;D....not interesting for you.,...I think.....AND: no sense is normal for my threats ;D
  • Meister-Schrauber
    • Bayern
« Antwort #21 am: 03 Oktober 2017, 13:25:10 »
b.t.w.
https://www.deepl.com/translator
is a much better translator than Google - check it out
  • Meister-Schrauber
    • Bayern
« Antwort #22 am: 03 Oktober 2017, 13:37:22 »
regarding your question about spare part retailers you will get almost everything for your R26 from either one of the four main suppliers in Germany:
Ulis Motorradladen
http://www.ulismotorradladen.de/
Rabenbauer
http://www.rabenbauer.com/
Stemler
http://www.motorrad-stemler.de/
Omega Oldtimer
http://www.omega-oldtimer.de/
grahamjb
  • Hobby-Schrauber
    • 6062
    • Perth
    • Western Australia
    • Australia
    Years
« Antwort #23 am: 03 Oktober 2017, 14:46:53 »
Great parts links
Thank you Borgward
Bency71
  • Schrauber-Lehrling
    • 67685
    • Erzenhausen
    • Rheinland-Pfalz
    YearsYears
« Antwort #24 am: 11 Oktober 2017, 15:13:48 »
Welcome. I have also bought a lot of things for my F650GS Dakar from this online-shop: https://www.motorcycleparts-hornig.com/BMW-F650-GS-F-700-GS-and-F-800-GS/
    • 45525
    • Hattingen/Ruhr
    • NRW
« Antwort #25 am: 13 Oktober 2017, 06:23:58 »
....but here it is an R 26 and not a F 650GS.
grahamjb
  • Hobby-Schrauber
    • 6062
    • Perth
    • Western Australia
    • Australia
    Years
« Antwort #26 am: 24 Oktober 2017, 11:51:07 »
Brian
I read in one of your posts that you have fitted the sidecar rated springs to the rear of your bike. Can you please advise if possible how they compare to the original springs whilst riding.
I am thinking of doing the same as I weigh 110Kg and I feel that some beefier springs might be advantageous.
Graham
bwprice100
  • Profi-Schrauber
    • SA8 3
    • Swansea
    • Neath Port Talbot
    • Wales
« Antwort #27 am: 24 Oktober 2017, 15:04:45 »
Brian
Graham
Hi Graham
Not having ridden it with the standard springs I can't make a proper comparison but the ride on the bike seems good with no bottoming out of the rear and not too harsh either.
I hope this helps
Brian
grahamjb
  • Hobby-Schrauber
    • 6062
    • Perth
    • Western Australia
    • Australia
    Years
« Antwort #28 am: 25 Oktober 2017, 16:06:11 »
Thanks Brian
grahamjb
  • Hobby-Schrauber
    • 6062
    • Perth
    • Western Australia
    • Australia
    Years
« Antwort #29 am: 03 November 2017, 08:15:58 »
Haven't been doing much on the bike lately due to being away on holidays
However I have made a front shock absorber compressor by copying Brian's (from England) design - mine is not as fancy as Brians but does the job.
