throttle twist grip slide worn out after 250 miles
Begonnen von Jollyjester, 18 Juli 2017, 12:26:59
Jollyjester
Problem with the throttle twist grip slide that pulls the inner cable to the Carb. It has worn so much on the 2 flats, that the twist grip is sloppy. Lot of movement before the cable actually pulls, It is made of what I would call, 'monkey metal, soft alloy, recall they were steel. I have marked to places where it is worn. After less than 300 k.  from new. Are steel available?
The actual  controls are well made. Came from Idealseitenwagen.eu
These replacement parts seem widely available for Stemmlers etc, but are they all the same.?
Jollyjester
Hi zusammen.
Hat hier irgendjemand eine Idee? Der Gleitstein scheint nach weniger als 300km verschlissen zu sein, ein bisschen Leerweg ist ja normal wenn ich das richtig in Erinnerung habe, aber...
Aus welchem Material ist der Gleitstein denn sonst? Stahl oder ein weichere Material?
Ich übersetze auch zurück...
Vielen Dank schonmal und schöne Grüße, Taz
PS@JollyJester: I took the liberty to repost in German, maybe we're lucky now..
Weicher...Zinkdruckguß
Es kann (wird wahrscheinlich) das Gegenstück...also die "Griffspirale" ...schon so zerschlissen sein das der Gleitstein immer kippelig geführt wird.
@Rolf: Vielen Dank  :blumen:
@JollyJester: According to Rolf the slide is always made of non-steel (to be more precise zinc diecasting)...so assuming that the controls are well and properly greased he suggested that the control itself (the "spiral") might be already so badly worn that it's causing the issues...you mentioned the controls "being "well made"....do you happen to know whether these are NOS, reproduction parts or refurbished old ones?
Best regards, Taz
