R2 advice on spark plugs ?
Begonnen von dequincey, 01 Juni 2017, 11:58:59
dequincey
hi, my specs are:
Old BOSCH denomination W240 (T1, T2)
have found some discussion on this, which plugs should i use, are new Bosch plugs reliable, if so, which one corresponds?
in NGK  some say B6HS but recently found a conversión:    in NGK  becomes :     B-8HS, B-8ES
which one is correct ?
regards
if once a man indulges himself in m.
dequincey
Dappsull
I am using the B8HS, which corresponds to the W240T1, works fine.
dequincey
thanks
i used B6HS, and now realized that was probably a mistake
ES...E is for long tread, H for short, you need the short one
Better is the BP8 HS...the Electroden (?) are more in the combustion chamber
6HS....if you are more a slowly driver....it can be ok (6 roundabout 200 Bosch)
dequincey
yes you are right, thank you
