R27 Charging Light Issue
Begonnen von sblaylock, 03 August 2013, 17:28:22
sblaylock
Hello,
I know this is a topic discussed often regarding the charging light staying on, however I have a couple of questions on how to repolarize the generator.
Do you do this with the bike running?
If not, should the key be in or out? If In, should it be in the middle position?
On the front board, I read you connect the battery + to D+ (Blue). However, D+ on my board is not blue (see attached). Am I looking at the wrong board. Any other info would be helpful.
Also, is there a recommendation on where to get an electronic voltage regulator.
Thanks,
Scott
sblaylock
Oh oh
D+ to B+ is wrong
Df to blue.....which direction goes the blue one?...to the regulator DF?
Check all (!) connections....then (!!) polarize the generator (running engine is better, you can do it also with nor running engine...better is running)
Electronic regulator....I take it from ZOFIA (look at ebay, roundabout 40€)
sblaylock
Hello Rolf,
So is this bike wired wrong then? I have the wiring diagram and it looks to me like the setup in my picture is not correct. Does anyone have a picture of the correct setup?
Thank you for the information on ZOFIA. I will look at ebay.
Scott
A picture??
What do you mean that it will show? The correct wiring....?
Because of the colours?....Do you know that your colours are right?
Hi Scott,
have you had a look into the "Betriebshandbuch" you can find under the topic "Literarur" --> "Handbücher"? Relating a picture of the wiring you can find everything you want. Seems to be interesting for us to see the wiring diagram you've used - so give us a hint or present a picture.
Rolf are correct in his statement, that you have to rebuild the hole wiring - but don't care; we are with you  :Frage:
Greets
Scott,
Rolf *and* Bernd are right ;)
Provided the colors of your cables in the harnesses are still correct (which unfortunately isn't the case with many old bikes), you have mixed up the black/red an blue cable (D+ and DF respectively). Here's the correct wiring per wiring diagram:
D+ Generator  -- blue --> D+ (61) Regulator
1 Generator  -- black -->  1 Ignition Coil
DF Generator  -- black/red -->  DF Regulator
So, simply check wether you have mixed up the DF and D+ connection points. Providing a picture of another R27 setup won't help, as we don't know whether *your* cables are correctly colored.
There's also an additional black cable at 1 Generator, not sure where this is going to and what it is needed for.
Cheers,
Searching for 'Zofia' may be somewhat difficult, so here's the direct link to the Zofia Oldtimerelektronik eBay shop:
http://stores.ebay.de/Zofia-s-Oldtimerelektronik-Shop/Lichtmaschinenregler-/
Cheers,
It is going to the cam shaft and needed for contact breaking. ;D :-*
Oops, yes, (blush)...
sblaylock
Hello,
Thank you everyone for the feedback. The wires are now corrected to:
D+ (Blue) - D+ Voltage regulator - Charging Light (Ladekontroll-Leuchte)
DF (Red/Black) - DF Voltage Regulator
I checked the rest of the wires and they seem to be OK.
Rolf/BenW, I found ZOFIA on ebay and ordered an electronic Voltage Regulator. It should be here next week and I will install it then. Thank you both for the help there.
Once I have the new VR installed I will post back here with my results.
Scott.
sblaylock
Hello,
Sorry for the late reply, I've been waiting for parts for the bike.
While I was waiting for the Electronic VR I found a NOS one for an R27 and installed it (see attached). I polarized the generator and the generator light goes out when the RPMs are above idle. Perfect! Well it all works fine until I turn the headlight on. If I run the bike above idle the charge light stays off. If I let the RPM drop to idle with the headlight on the generator light comes on, as it should, but when I increase the RPMs then Generator light stays on again and pulses. If I polarize the generator it works fine again until I let the RPMs drop to idle and generator light comes back on, stays on and pulses with RPM.
Is this an issue with the NOS VR? Will the Electronic VR fix this issue?
Regards,
Scott.
Seems that the field is loosing its polarisation at idle.
This may be an issue of bad ground connection (battery-minus -> engine casing -> frame -> VR-ground-connection).
But more probably its an issue of bad connections in the "DF-circuit" and charging-light-circuit, resulting in a too low field-current at idle.
Is the charging bulb of correct size (at least 2 watts, you may try 4 watt)?
Ruetz
Rützt...der hat denselben Fehler wie ich damals....du hattest es per Ferndiagnose rausbekommen....Masseanschluss im Batteriekasten falsch angeschlossen....die arme Lima musste sich ihre Masse immer über das Rücklicht holen.
Das wollte ich antworten....was ich natürlich vergessen habe abzuschicken...alldieweil das Nordlichttreffen losging:
I've hat the same problem...years ago....check your ground (-) in the battery case....you have the - cable wrong connected.
The generator has no real -....he get it from/over  the bulb or something else.
it, Rolf, it!  ;D
sblaylock
Hello Rolf,
That was the problem. The ground from the battery (B-) went directly to the motor only (see attached). On 16, terminal 4 only had the taillight - attached to it. I rewired it the same as the diagram and it works fine now. Thank you for all your help. I will take the bike for a long ride next week to see how it runs.
Cheers,
Scott
he...it....problem was solved! :P
Ich habe nun mal eine persönlichere Beziehung zu den Sachen! ;D
Scott: congratulations....the troublefinder was Rütz (years ago)....I only remember IT.
Pidgin Rolf
I had a feeling that you would write something like that.  ;D
