Installation of Lichtmaschine from Ulis Motorradladen? R25/3
Begonnen von FelixM, 08 August 2021, 20:56:06
FelixM
Nice graphics!
Anyway, checked the breaker point and it's 0,4 mm vs 0 (contact) I get 6,2 V from between moving part of breaker and earth when ignition is on.
I checked that there is connection between coil and spark plug (new ignition cable). But there is no spark...
Between closed points it's 0 ohm but when open I don't get unlimited  - I get around 25 ohm.
I cant see any apparent connections that should not be there...
The two plastic washers are correctly placed,  right?
FelixM
Krottenkopp
Are you sure that there is no connection to ground at the little screw?
Not at the plastic washers and also not at the ring cable lug ?
There will be never a spark if there is a connection!
Gruß Heiko/2
Gruß Heiko/2
