login
Autor Thema: My R25/2 restoration - few question  (Gelesen 222 mal)
Al Capone
  • Schrauber-Lehrling
  • I love BMW-Einzylinder
    • Rzeszów
    • Polska
« am: 12 September 2020, 23:22:49 »
During the restoration, there were some problems that I could not find answer on the forum. I allowed myself to create this topic in order to be able to cover it here and not to create a few threads.
1. After tightening the upper fork bolts, there is a 2mm gap on the left side.
I can't tighten the screw any more.
2.Do any of you know how the manual gearshift axle is locked inside the gearbox?
I can see one tiny hole there. Maybe some part is missing.
    • 44319
    • Dortmund
Re: My R25/2 restoration - few question
« Antwort #1 am: 13 September 2020, 09:41:50 »
Relating your second question:The position of the axle is fixed by a washer and a splint - in fact before the shafts (output and intermediate) are mounted.
Check it the axle doesn`t have too much clearance!
Al Capone
    • Rzeszów
    • Polska
« Antwort #2 am: 14 September 2020, 22:51:51 »
Hi Bernd
I really don't know what splint and washer are you talking about.  :traurig:
I'm suppose that hand shifter axle should be locked somehow inside. In other way I would might take it out any time. Have a look at second picture.
Krottenkopp
  • R 25/2
    • Hessen
« Antwort #3 am: 14 September 2020, 23:04:33 »
Of course inside!
With a split pin in the little hole and a washer...
https://en.m.wikipedia.org/wiki/Split_pin#/media/File%3ACotter_Pin_(PSF).png
« Letzte Änderung: 14 September 2020, 23:18:23 von Krottenkopp »
« Antwort #4 am: 14 September 2020, 23:05:56 »
wieder eine tolle Zeichnung!!!
Krottenkopp
  • R 25/2
    • Hessen
« Antwort #5 am: 14 September 2020, 23:12:02 »
Ich mal doch so gerne
« Antwort #6 am: 15 September 2020, 09:24:36 »
DAS SIEHT MAN; MONET! ;D
Al Capone
    • Rzeszów
    • Polska
« Antwort #7 am: 16 September 2020, 22:21:17 »
Thanks, so I should drill the axle right through becouse there is only one hole at the moment.
I had also solved first problem by using 1.5 mm spacer washer 50/40mm.
