Autor Thema: Flywheel  (Gelesen 974 mal)
Pederkr
  • Schrauber-Lehrling
  • I love BMW-Einzylinder
    • 2630
    • Taastrup
    • Copenhagen
    • Danmark
    YearsYearsYears
Flywheel
« am: 11 Juni 2019, 10:23:46 »
Hi there.
Is their any different for the flywheel on R 25/3 & R26
Peder
Flywheel
Re: Flywheel
« Antwort #1 am: 11 Juni 2019, 10:35:51 »
Pederkr
    • 2630
    • Taastrup
    • Copenhagen
    • Danmark
    YearsYearsYears
Re: Flywheel
« Antwort #2 am: 11 Juni 2019, 20:14:28 »
Yes i know that site, but i was thinking.
When the crankshaft is a 180 degeresse the weight of the crankshaft must be heavyer than the 90 degeresse crankshaft on late R 26 and R 27
This could explaine the different in height and there bye weight of the flywheel.
Now i have changed my Crankshaft from the late model 90 degeresse whit light metal conrod to the old model 180 degeresse whit iron conrod, and i will just be sure to get the flywheel that fit this configuration.
Dont want any vibration if i can.
Peder
« Letzte Änderung: 11 Juni 2019, 22:21:18 von Pederkr »
    • 91301
    • Forchheim
    • Franken
    • Germany
Re: Flywheel
« Antwort #3 am: 11 Juni 2019, 23:40:24 »
Hello Peder.
Not sure what you mean with 180 degrees or 90 degrees...and to my understanding the weight of the flywheel will only affect the ability of the engine to in- or decrease revs, impact on vibrations seems to be a little bit farfetched (apart from  maybe dampening effect due to shere mass) as the mass is evenly distributed and cannot compensate for weight changes of the crankshaft or the piston rod..
Just mho, Taz
Jollyjester
  • Hobby-Schrauber
    • PE15
    • March
    • Cambridgeshire
    • England
Re: Flywheel
« Antwort #4 am: 12 Juni 2019, 08:56:40 »
If you can eliminate vibration, you will have found the 'Gold' at the end of the Rainbow.
Vibration is a design feature, reduced yes, but not eliminated. There is the well known quote in England.
In the 1960's Mr. Vic Doswell, a  110% 'fan' of the singles asked an 'top man' at BMW, 'How do I eliminate vibration?'
'Buy a twin'
May I wish you many happy  free massage miles, or kilometers if you wish.
  • BMW E46 320ci, Z3 und R26
    • 87785
    • Winterrieden
Re: Flywheel
« Antwort #5 am: 12 Juni 2019, 10:31:17 »
Hi Ute,
I was wondering a bit as well, but finally figured it out: "180" is the "newer" steel con-rod crank shaft with 180 degrees tangentials of the crankweb edges, "90" the old one with the aluminum con-rod and 90 degree tangentials.
BR
Steffen
Pederkr
    • 2630
    • Taastrup
    • Copenhagen
    • Danmark
    YearsYearsYears
Re: Flywheel
« Antwort #6 am: 14 Juni 2019, 21:01:00 »
Hi Ute,
BR
Steffen
Genau / exactly  ;)
