R2 setting ignition
Autor Thema: R2 setting ignition  (Gelesen 1629 mal)
  • Ich 'abe gar kein BMW!
Re: R2 setting ignition
« Antwort #30 am: 28 Mai 2017, 20:26:03 »
Oder rechnen lassen: http://www.torqsoft.net/piston-position.html
  • Tips-Editor
    • Wattenscheid
    • Ruhr-Pott
« Antwort #31 am: 29 Mai 2017, 01:24:47 »
@ Tino, diese akademischen Spielchen habe ich zu genüge gehabt, bin sozusagen satt.
Ich suchte nach einer einfachen Möglichkeit zur Berechnung.
Vielen Dank an Stefan  :applaus: da sind ja noch viel mehr Sachen zu sehen ...
Gruß mek  :schrauber:
dequincey
  • Schrauber-Lehrling
  • broooooummmm
    • BIO
    • baskenland
« Antwort #32 am: 29 Mai 2017, 01:28:56 »
Oh, and what is a 'red light' - some LED device?
yes, a LED red light, worked only when i connected it reverse
plus multimeter was Reading -6 volts
can the bike engine run ? lights, and horn worked well
if once a man indulges himself in m.
Dappsull
  • Meister-Schrauber
  • Warum sind andere Maschinen sauberer als meine?
« Antwort #33 am: 29 Mai 2017, 08:04:27 »
Why don't you swap the battery connectors?
PS: what does 'once a man indulges himself in m.' refer to ;^) ?
dequincey
  • broooooummmm
    • BIO
    • baskenland
« Antwort #34 am: 29 Mai 2017, 10:46:22 »
swapping bat connectors worries me, but i will do so, probably next weekend
i am getting the necessary tools to carry on the work, such as a piston stopper, trying also to get a larger DTI arm to reach piston top through the spark plug hole,....
i will also print an angle disk and place it in a CD disk
lots of thing to prepare before
this weekend was fruitful to read all the documents, and learn about the theory, also set point´s gap correctly to 0,3 /0,5 mm (yeah 0,3 without manual advance is 0,5 with manual advance at máximum
i prepared a very freaky installation of an ammeter to check battery charging (will show you now)
p.s. "what does 'once a man indulges himself in m.' refer to ;^) ?"
well captured, Dappsull, is english writer Th.de quincey most famous sentence:
"If once a man indulges himself in murder, very soon he comes to think little of robbing; and from robbing he comes next to drinking and Sabbath-breaking, and from that to incivility and procrastination. Once begun upon this downward path, you never know where you are to stop. Many a man has dated his ruin from some murder or other that perhaps he thought little of at the time. Murder Considered as One of the Fine Arts (1827)."
i love the apparently absurd progression of things in his thinking
« Letzte Änderung: 29 Mai 2017, 10:49:57 von dequincey »
dequincey
  • broooooummmm
    • BIO
    • baskenland
« Antwort #35 am: 29 Mai 2017, 11:23:45 »
ok so the AMMETER installation
i was visiting the Essen motor show and found a Little nice object, a "Charging/discharging" gauge made in france in the 30-ies
it is essentially an ammeter (to measure Amps), so well what can i do in the R2 ? that was the question, was it posible to check when the batt is being charged or not ?
i went searching for a Bosch similar device and found nothing
i ended up in the UK, found this lovely patina ammeter from the 40-ies
then the question was how to prepare and where to install, so to make a long story short here you are the pics, any comments adn questions are welcome
it worked well :-) seems that the lichtmaschine ist kaputt :-(
regards
« Letzte Änderung: 29 Mai 2017, 11:50:36 von dequincey »
Dappsull
  • Meister-Schrauber
« Antwort #36 am: 29 Mai 2017, 12:30:42 »
Seems you're getting serious ;^).
Anyway, in terms of battery hook-up: can you check, if the '-' connector goes to chassis (which I assume should be the case)? But only then any measurement makes sense of course. Horn and lights are independed from polarity, but neither are the generator nor the regulator, even the ignition to a certain extend.
You are well equipped, so you can also follow up on resistances once you have acces to the generator and the regulator.
NB: interesting to get to know that ignition timing advance is changed by different point distance settings. An obvious way, but I never came across such a procedure (but I have of course only the super modern 1966 BMW).
Good luck!
  • BMW R2/-3; R4/-2
    • Rostock
« Antwort #37 am: 29 Mai 2017, 13:46:47 »
Did you flashed/polarized the generator?
  • BMW R2/-3; R4/-2
    • Rostock
« Antwort #38 am: 29 Mai 2017, 13:48:05 »
Ich bringe Leuten lieber das Angeln bei, statt sie mit Fischen zu füttern  ;)
dequincey
  • broooooummmm
    • BIO
    • baskenland
« Antwort #39 am: 29 Mai 2017, 15:01:54 »
 :prost:
dear Tino,
what do you mean ?
i do not understand
grussen
  • BMW R2/-3; R4/-2
    • Rostock
« Letzte Änderung: 29 Mai 2017, 15:27:22 von Tino »
bwprice100
  • Profi-Schrauber
    • SA8 3
    • Swansea
    • Neath Port Talbot
    • Wales
« Antwort #41 am: 29 Mai 2017, 16:08:31 »
My 2 cents.
You can calculate the current by measuring the voltage drop across a known resistance, no voltage drop the likely no current flow. The current can the be calculated using Ohms law.
Most current meters measure voltage drop and display current as result of Ohms law.
Brian
Sent from my SM-G920F using Tapatalk
dequincey
  • broooooummmm
    • BIO
    • baskenland
« Antwort #42 am: 29 Mai 2017, 22:31:59 »
http://www.vw-resource.com/alternator_generator.html#polar
http://www.dynamoregulatorconversions.com/polarising-a-dynamo.php
dear tino. this is extremely interesting, never seen this before, thank you so much for this lesson
but, my regulator is integrated inside the dynamo, so it will be difficult to follow this procedure:
"To polarize a Bosch or other series field dynamo for negative earth
 Disconnect the wires from the dynamo. Run a wire from the earthed (negative) terminal of the battery and hold it onto the DF terminal on the dynamo. Run another wire from the positive terminal of the battery and "flash" it onto the D+/61 terminal on the dynamo until a small blue spark can be seen.
The dynamos field is now polarized for negative earth and ready to safely connect to an electronic regulator."
if you can advise on how to proceed i would be very grateful
  • ommmmmh
« Antwort #43 am: 30 Mai 2017, 08:25:17 »
Do you have a "F" Regler?
  • BMW R2/-3; R4/-2
    • Rostock
« Antwort #44 am: 30 Mai 2017, 08:51:41 »
Usually it should be a Bosch F-Regler.
http://emw-r35.de/det/bosch_f_regler.gif
http://nsu-superlux.vogo.org/assets/images/Reglerk.jpg
In this case you have to hot-wire the cut-out (Rückstromschalter). Just for a split second.
For that remove the cover on the back of the generator.
dequincey
  • broooooummmm
    • BIO
    • baskenland
« Antwort #45 am: 30 Mai 2017, 22:31:23 »
i will look inside the generator, will do in the next days, thank you
thank you, Tino, that is usefull information,
i beg your patience, hot-wire the cut-out ?
ok, i need help to identify the cut-out, and also to know what is to hot-wire, and how to do it, it seems that i have no idea of what you are talking about, sorry
i will open the regulator and see what is inside first, i will take some pictures and come back here
MFG
  • BMW R2/-3; R4/-2
    • Rostock
« Antwort #46 am: 31 Mai 2017, 07:38:12 »
hot-wire = short circuit
dequincey
  • broooooummmm
    • BIO
    • baskenland
« Antwort #47 am: 01 Juni 2017, 16:52:37 »
Dear tino, will come back to this, later, vielen danke
dequincey
  • broooooummmm
    • BIO
    • baskenland
« Antwort #48 am: 01 Juni 2017, 17:28:41 »
so here i am, preparing the tools for this setting next weekend
so fa i have prepared:
a piston stopper, and a angle disk
  • BMW R2/-3; R4/-2
    • Rostock
« Antwort #49 am: 01 Juni 2017, 20:07:53 »
Hi, better put the degree wheel on the crankshaft.
When the crankshaft makes one turn the camshaft makes only a half  ;)
Also the chain has to much backlash for a proper result.
This could cause several degrees deviation to the crankshaft.
dequincey
  • broooooummmm
    • BIO
    • baskenland
« Antwort #50 am: 01 Juni 2017, 21:33:52 »
oh, Tino, you are right ! ....scheisse ! (sorry)  :(
oh i can do nothing with this, there is no way to fix it to the crankshaft !!!
i will use only the piston stop, then
thank you so much
dequincey
  • broooooummmm
    • BIO
    • baskenland
« Antwort #51 am: 04 Juni 2017, 10:19:16 »
so i did it yesterday, and it was a success
PREPARATION:
first i changed the battery poles, that were mistaken, and then checked the polarity in the coil, now terminal 15 is positive and 1 is negative, alles in ordnung !
then i rechecked the points gap: is 0,3mm without advance and 0,5mm when maximum advance
then checked for TDC using a plastic rod throught the spark plug hole, it was a bit empirical thoug, but i was able to make a painted mark in the flywheel, so i knew where i was
then using my other engine that is disassembled i set the piston stopper at 9,5mm: i removed the cyl head and place the piston at 9,5mm BTDC, then i adjusted the piston stopper accordingly
PROCESS:
i went to the motorcycle and placed the piston stopper in place in the running engine
i slowly moved the piston until it stopped, i made a mark in the flywheel for a 9,5mm BTDC
using my 6 volts red light (a diode, so it has polarity) i connected it: black cable to ground and positive to the condenser terminal in the ignition module (at last that now polarity is correct:_)
placed the lever in the handlebar at maximum advance, so ignition module is set at max advance (remember that this is moving the points anti-clock wise)
then using the cable adjuster of the ignition module i tuned the position of maximum advance so the red light (and thus the spark) was just switched on in that position of the crankshaft (9,5mm BTDC)
CHECKS:
once done i removed the piston stop and rechecked:
1- with maximum advance i checked that the red light just switches ON (spark firing) when passing through the 9,5mm mark in the flywheel
2- now i put no advance with the lever in the handlebar
3- i checked when the spark is produced in this condition, and i found that spark ignites AFTER TDC !!! only a few degrees but ATDC, surprising !
ENJOYEMENT
and finally i started the engine, wow, so loovely !
no knocking at all, started very well, i assume also new points and new condenser where part of it !
AKNOWLEDGEMENTS
thank you all very very much, now i understand my motorcycle (it has been 10 years ;-))
...it will continue ...
« Letzte Änderung: 04 Juni 2017, 13:19:13 von dequincey »
Dappsull
  • Meister-Schrauber
« Antwort #52 am: 04 Juni 2017, 13:31:15 »
Congrats amigo!
It was a bit the Th.de Quincey approach: start with connecting the battery properly (start with murder....) and work down from there ;^)
Cheers!
dequincey
  • broooooummmm
    • BIO
    • baskenland
« Antwort #53 am: 04 Juni 2017, 15:36:46 »
thank you Dappsull
Look at how it looks like, sorry for lack of clarity of the explanation
Dappsull
  • Meister-Schrauber
« Antwort #54 am: 05 Juni 2017, 12:47:58 »
Nice videos.
Now does it run properly and you can take it out for a ride?
Have fun!
dequincey
  • broooooummmm
    • BIO
    • baskenland
« Antwort #55 am: 05 Juni 2017, 13:40:39 »
Nice videos.
Have fun!
thank you
not yet, now i must deal with the carburettor
step by step
thank you
dequincey
  • broooooummmm
    • BIO
    • baskenland
« Antwort #56 am: 05 April 2018, 15:57:41 »
hello
i am back
there is a warning that this post is more than 120 days old, but it is mine, so i need to respond because i have good news
dequincey
  • broooooummmm
    • BIO
    • baskenland
« Antwort #57 am: 05 April 2018, 16:05:44 »
first thing is the carburetor thing, ok i am still dealing with my new bing carb, i still dont have the time and the guts to plug back the original fischer amal
ok, you might remember that i learnt all those good things about the ignition setup with your great help, and then it was time for setting carb and mixture and iddle, but, no way, too high revs and no way to set iddle,...
...the point was finally clear, i made a mistake with the setting of the accel position so the cable was always pulling a bit and the bell was always 5mm open, yes, nice one, right?
o so i fixed it and i have a nice video to prove my smoooth iddle, please do tell if you think is too low, i am still dealing with the transition, but i am pointing in a good direction IMHO
nice thing is that i have been able to make the smoky exhaust clean now, so mixture seems good,...
  • ommmmmh
« Antwort #58 am: 05 April 2018, 17:30:28 »
It isn't too low.....good idle....if you will drive....for show it could be lower (many people do it so), but that wasn't good for accelering and engine (oil pump)
Dappsull
  • Meister-Schrauber
« Antwort #59 am: 05 April 2018, 17:32:18 »
Sounds pretty cool - congrats!
anything
