Final Drive Issue login
Autor Thema: Final Drive Issue  (Gelesen 457 mal)
KillerTux
  • Schrauber-Lehrling
Final Drive Issue
« am: 10 März 2017, 03:42:15 »
I have renewed the seals, bearings in my R2 final drive. Once it was all assembled, the drive did not spin like it used to, it was binding up. I looked for an answer on the forums, it is exactly as posted in the link below:
http://bmw-einzylinder.de/forum/index.php?topic=10523.0
What would be the solution to the play between gears? Thank you in advance, I am learning a lot by reading past posts. Google Translate is great.  ;D
Final Drive Issue
KillerTux
Re: Final Drive Issue
« Antwort #1 am: 18 April 2017, 01:42:45 »
I found out the issue. BMW used a non standard bearing the the R2 and R4 final drives. The standard SKF 16012 bearing looks correct with the bore and out diameter but it is just a little too tall.
anything
