Generator warning light came on at high revs
Begonnen von BSA Bob, 18 Mai 2025, 12:38:09
BSA Bob
Today I let my R26 rev out in 3rd gear uphill. At slightly over 80kph the generator warning light came on. I backed off, the light stayed on for about 20 seconds & then went out. Everything's working OK since.
Does anyone have an idea of what this could be? I haven't a clue.
The bike has an original setup, original generator & mechanical regulator.
BSA Bob
CowBoy
It could be that the armature isn't running quite right. Then the carbon brushes jump and the red lamp comes on.
Cheap and easy: clean the grooves of the collector on the alternator with a wooden toothpick. Have a look at the brushes. Worn out? Springs tension is OK? No wires loose? Are the brushes easy to move in their guidings?
BSA Bob
Thanks for the replies.
I thought about the brushes jumping but figured the length of time the light was on (well after I backed right off) meant it wasn't that. Anyways I had a good look today & can't find anything- the copper faces are clean with no dirt between them, no loose wires & the brushes look OK.
I'll wait to see if it happens again.
patro
I'm not quite sure if it's the same with R26.
But with my R25/2 every now and then I had this issue with the ignition nail. I don't know the right translation to English language. Especially in a rough environment it happens that the nail is jumping out and the contact is disconnected.
So you could try it with a bungee wrapped around the lamp to fix it.
Meanwhile I repaired ignition platine by bending the contacts.
Motorradmechaniker i. A.
Gruß, Ralf.
R25/2 | KR51/1
In this case, the ignition would also be interrupted but obviously only the charging indicator light came on
Armature/collector out of round is plausible for the symptom. ( jumping brushes )
Also bad ground/earth connection(s) were possible.
I had similar issues a few times now, getting worse until the generator light didn't come off again at all
and the battery was completely discharged.
The collector looked perfect, like from a book how it schould look.
Nevertheless Timmäh gave me the advice to carefully grind it with 400 Grit Paper.
We were on a trip and far from home, so we had to come up with a solution right there, right now.
We removed the sparkplug and generator lid.
One guy pushing the sanding paper to the collector, another one turning the engine over by Kicker a few times.
Afterwards we cleaned up the collector with a fuel-soaked, clean rag.
That did the job ! Battery was charged again and we reached home without further issues.
Long termed solution was trueing the collector on a lathe and install new brushes.
Since then the issue didn't occur again.
BSA Bob
Hi folks, thanks again.
Patro, as Borgward says there was no interruption to the ignition when this happened & my ignition lock's in good condition. Your English is better than my German.
4Taktix, I'll recheck the wiring for loose connections but I'm pretty sure it's OK.
When this happened I was revving the bike a bit harder than usual, I don't go over 80 in 3rd & rarely at that. I don't thrash the bike, if I want to go faster I can get something else.
