Coupling flange torque
Begonnen von georendt, 03 November 2019, 21:03:58
georendt
Hello from Canada, can anyone give me the torque for the nut on the Transmission coupling flange for a R 24? It's the one that uses a special socket which I made.
georendt
Kurt in S.A.
Can't seem to find any numbers for my R25/2, but can read that the value for my R69S coupling nut is about 160 ft-lbs.  My guess is it's something like that for the R24.
Kurt
Kurt in S.A.
Fred
according to R26/27 repair manual the required torque for  #26 in above picture is 12 - 15 mkg - should be in the same range for an R24
(corresponds to 117 - 147 Nm or 85 - 110 ft-lbs)
georendt
Yes #26 thank you, very much appreciated. I did replace the washer and nut with new also!
