My R27 is now on the road
Begonnen von SteveMKentucky, 25 Oktober 2018, 00:45:08
SteveMKentucky
I started a thread some time ago to document the restoration of my bike.   There seemed to be very little interest in the thread so I stopped posting.  Nonetheless, it's now completed and I've taken it on five or six half-day runs.  There were a few small issues to sort out but she seems to be running great for now:
SteveMKentucky
SteveMKentucky
Moderator, bitte löschen Sie den zweiten Beitrag.
grahamjb
Hey Steve,
nice one! How does she ride? R27s get rare, keep an eye on it  :bike:
best regards,
Steffen
looks great- well done and enjoy.
The side Stand is not scraching the road in left bands?
Best regards Jan
bwprice100
Very nice Steve.
Brian
Sent by me using tapety talky
Attention...your sidestand is a killer!....is has to disappear under the exchaust
RolfD
SteveMKentucky
Yes, I know.  The sidestand tends to catch on the header clamp.  I always make sure it's fully up before riding.
I had just had it on the sidestand and put it on the centerstand for the picture.  I didn't notice that it was not fully up until after the pictures were taken.
SteveMKentucky
Zitat von: OldsCool! am 25 Oktober 2018, 08:23:59
Hey Steve,
best regards,
Steffen
It rides great Steffen.  I must say it's very different from my larger bikes.  Each gear has to be wound up quite well before shifting into the next.  But it is great fun to ride.
Try to get a 27/6 instead of the 25/6 transmission.....it´s a new motorcycle with that transmission. in Germany it is called "Behördenübersetzung" because the cycle for police, army etc has that transmission
SteveMKentucky
#12
Thanks for the tip Rolf.  Not sure where I'd find one but will begin looking.
By the way Rolf, do you know if it's possible to replace individual gears within the gearbox to duplicate those in the "27/6" gearbox?  If so, do you know the ratios?
Yes...I think it`s possible....you can take gears from the twin gearboxes....for the ratios i am too lazy to calculate....changing the rear transmission is simpler to do. R27 from (roundabot) 65 has the "new" transmission
bwprice100
I have a friend, Brian Thomas, who has an R27 and I'm sure he put the internals from an R69S gearbox into his R27.
I think he changed the carby for one from a pre 69 500 twin as well.
It might be worth speaking to him.
Brian
Brian,
that is not the question (I hope ;D)....the internals are interchangeable...but what ratios you will take?
bwprice100
Zitat von: rolf am 26 Oktober 2018, 14:35:10
Brian,
Hi Rolf
He did it to get better ratios but not sure of the differences though. ;)
SteveMKentucky
Yes, I've heard about using /2 gears.  I'm just curious what the ratios that Rolf mentions are.  I'll do some research and see if I can find the specs.
I'm aware of the carb mod too.  I actually have one.  The carb is from an R50/5.  I found a couple of problems with the carb conversion.  First was fabricating a choke lever as the original uses a cable system.  The second is that the rubber bellows from the carb mouth to the airbag doesn't fit.   Fact is, my stock carb runs pretty well.  However, the /5 carb does have a better fuel bowl arrangement and it reportedly has a better idle circuit.
Changing individual gears is not possible.
The secondary shaft is casted - so only one gear can be changed and that is the second gear of the "gear-triple".
Of course you can change the "set" of the gears from the twins (up to R29S R69S) into the housing of your R27. The first three gears then will be "longer" the 4th gear has the same transmission-ratio.
If you want to realize a shorter transmission-ratio you should have look for the "behördenübersetzung".
Hope everything is understandable and it helps
Regards
SteveMKentucky
Of course you can change the "set" of the gears from the twins (up to R29S) into the housing of your R27. The first three gears then will be "longer" the 4th gear has the same transmission-ratio.
Regards
Yes, thank you Bernd.
The following link is to a thread on the Vintage BMW site that discusses (among other things) installation of a /2 gearset. The author also discusses using a 27/6 final drive ratio.  Please let me know if you can't see the thread without logging in.  The gearbox discussion starts at post #17:
http://www.vintagebmw.org/v7/node/7381
No doubt, that it is possible to modify the gears by changing the shafts including the gears.
But have look onto what you want! If you wish a shorter transmission ratio use the shorter final drive - if you want "longer" ratios use the /2 gearset.
Mixing both may be interesting - one can calculate what happens in that case
Regards
grahamjb
SteveMKentucky
klawo
Steve,
well done :applaus:
Very, very good!!!
Klaus
