login
Autor Thema: washers thickness output shaft and cardan shaft R25 / 2  (Gelesen 425 mal)
Anto
  • Schrauber-Lehrling
  • I love all motorcycles
    • 89861
    • Tropea
    • Italia
    YearsYearsYears
« am: 10 Oktober 2020, 15:26:05 »
Hello everybody. I wanted to know if the washer indicated in the photo with number 30 on an R25 / 2 is a fixed measure or is it to be determined together with the thickness of the washer at the end of the cardan shaft for adjusting the distance between the flanges?
Is the distance between the outlet flanges 30 + 1.5 like R25 / 3? I believe the two trees must not touch each other but be close enough for the rubber and the pins.
Thanks and best regards, Anto
  • ommmmmh
Re: washers thickness output shaft and cardan shaft R25 / 2
« Antwort #1 am: 10 Oktober 2020, 18:49:22 »
"For adjusting the distance":::::AS YOU READ THERE SHOULd BE A FREEPLAY OF the "Getriebewellen" in the housing of 0,2mm....you have to measure it....and then take a washer in the correct thickness
« Letzte Änderung: 10 Oktober 2020, 18:50:54 von rolf »
Anto
    • 89861
    • Tropea
    • Italia
    YearsYearsYears
« Antwort #2 am: 10 Oktober 2020, 20:08:43 »
Hi Rolf, thanks for the reply. As always, you are very kind.
Did I interpret your answer correctly? Look at the picture. 0.2 mm free between output shaft head and cardan shaft? Thanks again. Sincerely.
  • ommmmmh
« Antwort #3 am: 10 Oktober 2020, 20:14:03 »
no
nothing to do with the flange...the washer is for INSIDE the Gearbox
by the way....the cardanshaft goes inside the output shaft head
Anto
    • 89861
    • Tropea
    • Italia
    YearsYearsYears
« Antwort #4 am: 10 Oktober 2020, 20:29:37 »
Maybe I don't understand well translating. So let's see now: the gearbox output flange has some distance from the bearing. Does this distance need to be compensated for by a washer of equal thickness?  And 0,2mm  what does it refer to?
Krottenkopp
  • R 25/2
    • Hessen
« Antwort #5 am: 10 Oktober 2020, 23:00:06 »
No, there is no washer for the flange!
The washer is between the bearing and the housing cover to reduce the gap there to 0.2 mm. (Have a look at the green arrow)
Therefore it is necessary to take a washer with the right thickness or a combination of two different ones.
Gruß Heiko/2
  • ommmmmh
« Antwort #6 am: 11 Oktober 2020, 00:58:27 »
Deine Zeichnungen....immer wieder ein Gedicht! ;D
Krottenkopp
  • R 25/2
    • Hessen
« Antwort #7 am: 11 Oktober 2020, 05:33:03 »
Die Sprache der Kunst benötigt halt keine Übersetzungen.
Gruß Heiko/2
Anto
    • 89861
    • Tropea
    • Italia
    YearsYearsYears
« Antwort #8 am: 11 Oktober 2020, 05:40:25 »
That's why I couldn't understand. I wanted to know if this empty distance indicated with the blue arrow had to be compensated or not with a washer: from the table we deduce that NO. I believed wrongly that this distance had to be adjusted by washers of various thickness to keep the distance between the two flanges at 30 + 1.5 .... But NO!
  The shim instead of the bearing, the one in green, was already adjusted when I closed the gearbox cover because I replaced the output shaft which was defective. Congratulations on the very clear table; how can i get it?
    • 45525
    • Hattingen/Ruhr
    • NRW
« Antwort #9 am: 11 Oktober 2020, 08:26:19 »
 :lol: ;D
Noch 16 Jahre bis zur Rente...
Anto
    • 89861
    • Tropea
    • Italia
    YearsYearsYears
« Antwort #10 am: 11 Oktober 2020, 08:53:39 »
 :lol:
Adresse
