TERMINE und FORUMSTECHNIK => International discussion forum in english language => Thema gestartet von: Kurt in S.A. am 28 Juni 2020, 19:27:08
Carb is 1/22/44. I'm thinking I might not have the idle air mixture set right. My Bing manual says the setting is 1-1/2 turns out. Does that seem right? Usually that's a starting point, though. How does one go about fine tuning that? Do I get the engine warmed up and change the number of turns in (cuts out some air to make richer) and out (lets more air in to make leaner) and find the spot where the RPM goes the highest? Maybe then a slightly bit richer from that point?
Thanks...Kurt
Thanks...Kurt
Hi Kurt,
the values you are mentionning seems to be right, my docs are saying same.
But do any basic adjustments to the carb's settings only when the engine is in good working condition and really warmed up.
Oel temp should be stabilised around 70 to 80° to get an stable idle. A short ride will get the engine to that point.
HansO
Thanks, HansO. I'm more comfortable doing something like this on my R69S or my /7, although on the /7 I'm controlling a gas circuit, not air. Also in those cases, I'm trying to balance the two cylinders...I still seem to only have the one on the R25/2! ;D
Kurt
....and find the spot where the RPM goes the highest? Maybe then a slightly bit richer from that point?
Exactly like that !
Cheers,
Just checked...the adjustment was at about 3/4 to 1 turn out. So, I reset it to 1-1/2 turns out. Will need to final adjust at the next ride.
Kurt
Kurt
Hi Kurt,
when there a solution has been found, eventually a problem may be solved !
But don't forget : one resolved often means two new ones will propperly appear, soon.
Be happy, don't worry and good luck,
Hans
Well, you're probably right. I'd posted about this before, but one issue that had been bugging me is some popping of the exhaust when I close throttle to shift gears. I checked valve clearances last week and found them good, except that the intake was a bit tight...I like to run it at 0.15mm...exhaust was 0.20mm where I had left it. The ride this past weekend showed the popping to be quite reduced, although I highly doubt that such a small change was the reason.
The other thing that I'm trying to resolve is that the engine surges a bit when running in lower gears at slow speeds in the neighborhood. I was wondering if maybe my idle jet was too small...I don't know precisely if it is the 35 called out in the specs...it's been a while. Then I thought about the mixture setting and how it might be affecting part throttle running. I understand that the regimes of carb operation - idle jet, needle jet, main jet - all overlap at various throttle positions. So, I'm trying to get the carb set where it should be and go from there.
Kurt
Hi Kurt,
find the setting as described. then make a test: try to find a "mountain road" an let the bike roll on high revs downwards. If the setting is too weak, there will be "bangs" to be heard in the muffler. Too, if the washer between exhaust and cylinderhead is worn out.
You will see, that there is a very small turn between "too weak" and perfect.
Good luck,
right, lean mixture can cause the popping. As leaks in the exhaust also can do.
One other potential cause are the ignition-advancer-springs.
If they lost tension over time, the fly-weights need lowers revs, until they swing back to their "late" position - the ignition is advanced although it isn't supposed to.
To check this, remove the generator lid, connect a strobe gun and aim on the advancer. Works best in a shaded or dark area.
Now rev it and watch the weights while closing throttle and rpm drops.
If they don't swing back till shortly before idle-rpm, it maybe worth a try to renew the springs.
But I suppose there will be an improvement already by setting idle more rich.
Next step could be to lift the needle one position - enrichens the next regime above idle. If required.
Cheers,
Sascha -
In the position I found it, the idle mixture was screwed in too far, shutting off air making the idle circuit more rich.
The surging around the neighborhood at slow speed seemed to begin middle of last year when I lowered the needle from the 3rd to the 2nd position. Ever since I got the bike, the mileage was around 50 mpg (US). I felt it should have been better than that. So I made the "crude" adjustment with the needle. Now the gas mileage is more like 63 mpg. I spend most of my time on 2/3-3/4 throttle so I'm likely on the main jet as well. I was thinking that the needle adjustment might have affected the low range idle circuit.
I'll have to consider the advance springs...they might be original for all I know!!
Kurt
Well, today was the day to get the bike out to warm it up and then come back and adjust the idle mixture. And that's where the fun begins! I had left it at 1-1/2 turns out. I loosened the lock nut and turned the screw many turns each direction...I heard no change in engine RPM. Hmmm. Guess something is plugged. Prior to this the screw was less than 1 turn out. On today's ride, the popping on gear up shift when I roll off the throttle was virtually gone. I still had the minor "hunting" after the ride and I was slowing heading back to the house in the neighborhood. So, I decided to turn the screw 2 turns out and will see how it runs next time.
--- update --- As I think about it, if it didn't make any difference when I moved it with engine running, resetting it to 2 turns out probably won't make any noticeable difference. :spinnt:
Kurt
Hi Kurt,
sounds like something other then the mixture screw is limiting/adjusting your idle-rpm.
Not sure what is stock on R25/2 - but check, if the mixture (idle-air) screw has a longitudinal bore with 2 tailings beneath a little tin cap.
Maybe this is clogged and prevents proper setting.
See this thread, post #19, pic #7
https://bmw-einzylinder.de/forum/index.php?topic=16214.0
Cheers,
Sascha -
I'm typing a second time...tried uploading a picture that was already on the forum. :(
Anyway, I don't have that little "cap". I'm familiar with this on my R69S. In the link below, look at the first picture. I don't see how there's any room to fit a cap on it. I thought the cap was more or less a crude filter to keep debris from getting into the hole that is on the screw.
https://bmw-einzylinder.de/forum/index.php?topic=18077.0
This is the way the bike came to me. I might just back the screw fully out and examine it more closely.
Kurt
Hi Kurt,
seems there are two different screws available, a short and a long one. Whereas the short is assigned to R24.
Check this out:
https://www.ulismotorradladen.de/artikelliste/Vergaser_Luftfilter_BING_Ersatzteile.aspx?BildNummer=V030
both versions displayed on that site. --> "Gemischregulierschraube"
Looks like you got the short one, thus no room for the cap.
No Idea, if the carb works as intended with each of them.
The explo shows the long version including the cap - parts 30,31,32. Which is correct for R25/2.
Position the mousepointer onto each particular part in the explo until it's highlighted, then click.
Will display the german term, order-number and price in the right window.
Regards,
Interesting. I wish all companies used the same part numbering!! When I look at my Bing manual, the R24 had the T77 carb while the R25-on carb was the T115. Further notice that the parts you're pointing to on the R25/2 carb are identical to those on my R69S carb (T120).
I'll have to take out my short screw and see what's going on. I suppose I could "borrow" the set up from my R69S and see what the difference might be.
--- When I look up the parts on the Benchmark Works site here in the US, they list the following:
13 11 0 039 180----carburetor idle mix screw Bing R24-R25/2 R27
That seems to suggest that there's only one screw used for all the singles. Something's not right here.
Kurt
the Explo covers different models, see Title: "Vergaser + Ersatzteile, Luftfilter:R24-R69S"
= Carb and Sparparts, Aircleaner...
So its like a general example for Orientation.
Concerning the part-numbers you were absolutely right.
Recently I learned my lesson here: Rabenbauer.com uses original BMW Part-numbers.
So you can spend the nightime to cross-check against other dealers via Searchterm, Drawings and sketches, until you are halfway sure, to order the desired part ;-)
I never heard the carb-model-terms you mentioned. Maybe it's something BING-internal.
But it's common, that many parts are equal among different carbs. As e.g. the main jets.
Also in my link it says for the long screw: "Gemischregulierschraube für BMW R25-R69S, lang", so there's nothing odd with it.
Borrowing the parts from your Boxer is what I'd do first.
I happened to go to Mark Huggett's site and see that for the R25/2, they're calling for the shorter idle mixture screw without the "cap". On this page, it's part #26 on this page...part 13 11 039 180...click on the "info" letter on that line to see the picture.
https://www.bmwbike.com/index.php?e=mhs#nav-sub2
Mark shows that beginning with the R25/3, the longer screw was used.
I haven't tried removing the current mixture screw on my bike but will get to it. When I do, I'll also pull the air cleaner and then spray some brake cleaner in from the mixture screw side and see if there's anything coming into the carb throat.
Again, there's conflicting info depending on where one goes to look.
Kurt
I checked with Bing here in the US and they confirmed that my carb should have the longer screw with the sleeve and cap. So, I have that ordered and now installed in the carb. Have set it initially at 1-1/2 turns out. Before installation, I squirted carb cleaner into the hole and the liquid came out in the throat of the carb so that lets me know that the orifice is clear. While I had the air filter...er "rock strainer"...off, I went ahead and cleaned it and put another coating of gas/oil on the mesh. I used a 10/1 mixture of gas to oil...the gas evaporates off leaving the oil behind.
I'm anxious to give it a ride to see what kind of difference it might make.
Kurt
an anxious Texan - from San Antonio - secret heart of the Lone Star State -surely, yes of course.
Now tell me you are shy ! ;D
C'mon, Remember the Alamo ! :attacke:
We're not shy here! Texas was the only state to have been under six different national flags! We got around!!
Kurt
Well, that was disappointing! I finally got back to riding the bike and upon return, I set about adjust the air mixture screw. It made no difference in idle RPM. I even seated the screw...no change. Previously, I had sprayed carb cleaner into that hole and had the liquid come out inside the throat of the carb, so that suggests at least that path is open. Maybe something else is blocked?
I'm not real sure what's going on...might have to take the carb apart.
Kurt
hey Kurt,
your idle screw without cap is original, forget what other people say....2. this one or with cap wasn´t the problem. ...they were (as you do) interchangeable without any problems.
I did not really understand your problem....the idle did not change when turning the screw?
What is when you turn it nearly to the ground? Also no change?
Rolf -
Interesting about the air screw. I called Bing here in the US and they said for my carb number, I needed the longer one with a hole. There is conflicting information on the web at the various parts sites.
Yes, with engine idling, turning the air screw either way, numerous turns results in no change to the engine RPMs. I even lightly seated the screw and no change to the engine running. In the case with the original shorter screw, I'm not sure what it's function is. Without any hole down the middle, it is very difficult for air to pass between the threads of the screw from the outside to the inside of the carb. Therefore, the sharp point of the air screw must be opening/closing some passage within the carb. And since turning the screw...either of them...results in no engine changes, that passage must be plugged.
Kurt
believe it or not.....the idle screw without caps is original ....but, never the less, it is not important....they are complete interchangeable
the little hole inside the idle screw is NOT for air INTO the carburetor....it is for gasoline OUT of the Carburetor
The only air for the carb comes the holes in the Carb.....the hole that you can close with the idle screw by turning clockwise
if your engine (OR CARB) did not react by turning the idle screw to the ground.....you get air on another way to the carb....in german "Nebenluft":::MOSTLY OVER THE FLANGES OF THE CARB.
proof it:start the engine....at idle spray a little bit start pilot, brake cleaner or something else inflammable ob the flange or all of the carb.....when the idle is changing....you got where the carb gets his Nebenluft....then ask again to eliminate this
Rolf -
OK, good idea. I hadn't thought about air getting into the carb via other paths. I'm aware of this on my twin cylinder bikes...will have to check that out. It might take a bit of time before I can get back to try this.
Kurt
no hurry
I'm back...but have no good news to report. I went out for my usual spin and was prepped to spray carb cleaner all around the carb when I got back. I took off the inlet filter as I didn't want to dilute the oil coating I recently put on the internals. I didn't encounter any changes to engine RPM as I sprayed from where it joined the head to all around the carb. I guess the only thing left is to do a very through exam of the carb after I disassemble it.
Kurt
I'd treat it in an ultrasonic bath with the appropriate cleaner after disassembly.
I suppose that some part of the idle-system is still clogged, that makes the setting of the idle-mixture-screw effectless.
The carb cleaner is inflammable?
I'm pretty sure my carb cleaner will burn. It's called Brakleen made by CRC and has a red diamond on the side that says "flammable".
Kurt
flammable....the gas or the cleaner?
SPRAY A LITTLE BIT ON THE GROUND AND THEN TRY TO :kopfhau: made it burn with a match...only for sure
OK, you made me do it!! Play with fire!! Yes it does burn. :waffen093:
Kurt
so....now it becomes a miracle....it must be "Nebenluft"...but where????
I´ll think about it.
Kurt,
paint konic part of the idle mixture screw with an Edding.....screw then the screw into his hole until you ment it is full screwed in.....then screw it out.....is there any ring visible on the Edding marking?
rolf -
Not sure what you mean by "edding". Are you referring to some kind of blue-ing compound? I guess you're wondering if the screw actually seats.
Regardless if the screw seats, it seems that turning it 1-2 turns from the starting point (about 1-1/2 turns out) resulted in no RPM change.
Kurt
Kurt, what Rolf meant is: use a broad permanent marker to check, if the tip of the idle screw is touching the bypass correctly.
BTW, edding could be used too, to mark breakpads to ensure correct position and wear in the break drum...
OK, I googled Edding and see that it is a German company that makes writing and marking pens! Now, if you had said Sharpie, I would have known right away! :D
Kurt
Kurt,
paint konic part of the idle mixture screw with an Sharpie.....screw then the screw into his hole until you ment it is full screwed in.....then screw it out.....is there any ring visible on the Sharpie marking? :P
I'll give it a try in due course. I'm currently 1000 miles away from the bike!
Kurt
Got back around to it. Here are two pictures of basically opposite sides of the screw after seating it. Looks pretty normal to me...I didn't turn it too hard but figured I got a good seat. Any insights?
Kurt
hey Kurt....looks good....what a pity....it seems to get contact roundaround whn screwing in....however witha VERY thick ring....normal is a small line
once again....no idle changement when you screw in the idle screw? And also no "Nebenluft"? It cannot be so!
Rolf -
As for a thick vs thin ring, could be that the interior hole in the carb has worn a bit over the years. I did not retry the screw to see if it made a difference in the idle speed...I had done that before with this very same screw and it made not change. One thing I would say is that after my ride, the surging I have been getting when returning to my neighborhood was absent. So, I'm not sure what to make of that.
One other "funny" thing happened on that ride. I keep track of my gas mileage and use the results of a fill up to calculate when the tank will go to reserve the next time. I write that number on a piece of tape on the gas cap. When I left home this time, I noticed I was relatively close to the number on the tape so I headed straight for the gas station. Less than a kilometer from the gas station, the bike stumbled and stopped running. I have a clear plastic filter and could see there was no gas in it. I was shocked because the odometer read earlier than my piece of tape!! Hmmm... I was on a hill down to the gas station so I just put in neutral and coasted to the pump.
When I got home, I rechecked my calculations. Turns out the number I wrote on the tape was "exactly" the distance to reserve. Typically I write a number that is say 20 kilometers before reserve so I have a bit of cushion. So, I goofed this time in picking my target mileage for heading to the station. I could have turned the petcock to reserve to get another couple of liters of fuel...but I generally don't drive deep enough into a tank to need reserve so I didn't think of it. Plus I had the downhill coast to the pump so I didn't have to push the bike for that distance!!
To complicate things, I have been doing some tweaking of the idle screw and checking for leaks which meant that I burned up fuel sitting in the driveway. That's why I burned the fuel in the main tank earlier than I had predicted. Live and learn!
Kurt
kann mir das jemand übersetzen....mir ist das zu englisch ;D
Kurt....I ask for a translation to the forum....my english is not good enough
...irgendwas mit "Tank früher leer als errechnet" und Motor aus und bergab auffe Tanke rollen.
Nix, was zur Problemlösung beitragen würde - zumindest kann ich das nicht erkennen.
No, nothing to help solve the problem! It was gas related and just thought I'd share!! :prost:
Kurt
Sascha:
Since it appears that air is getting into the idle circuit some way and not from the outside connections, is it possible that the slide is worn or the carb body is worn on the inside? Is there a way to confirm this? I will likely need to remove the carb and physically look at the looseness of the slide. I've priced a replacement from my US source at around $35 which seems pretty cheap.
Kurt
Hi Kurt,
very simple: detach the carb - slide in idle position - one finger into the intake-side, one other into the outlet-side, then try to move the slide back and forth.
Repeat in various positions. I suppose you will notice that the sideplay decreases, the higher the slide-position.
If so, there is definitelty some wear. Replacing the slide is easy, but the wear will also be in the carb-body, which is harder to eliminate.
Maybe for 35 bucks it's worth a try - depending on the quality. Does the internet have rumours about that replacement carb or that dealer ?
Another possible root cause may be a crack in the carb-body. But you'd have noticed that by rpm-change while spraying with the cleaner or whatever flammable you tried.
Also check the cable-inlet on the top-lid - there's a rubber sleeve available to prevent air from bypassing the slide that way.
You could pre-check this by wrapping tape tight around the cable-inlet.
Regards,
Nice weather outside so I decided to investigate further. The slide is not the problem. It fits very tight in the bore. I do recall having some sticking issues in the past and had done some light "buffing" on the outside of the slide. It moves up and down with throttle easily. But the slide can't be the problem.
I verified that the hole from the air bleed is open to the throat of the carb. But there's another hole upstream of that. This is a bad picture...best I could do. The air flows from the bottom of the picture to the top. What you're seeing is the top of the atomized in the bottom of the chamber. I've circled what appears to be a hole downstream of it. Note that the hole from the air mixture screw is a little further downstream of the hole that I've circled. I sprayed cleaner in the circled hole but didn't see where any of it came out somewhere else.
Lastly, I thought I should check the flatness of the carb flange. It looked flat! But I rubbed it on pieces of 600 grit sandpaper with some acetone, going each direction a number of times. It did appear that it wasn't flat. I continued until I got shiny material all the way around the main throat opening. Lastly, I put some blue hylomar sealant on both sides of the carb spacer as well as around where the carb cap screws onto the cap. I'm thinking that maybe air was leaking around this flange.
Kurt
THE "Mischkammereinsatz" is in right position?
ps
danke, Sascha :-\\
I believe it is, Rolf. As I recall, it only goes in one way.
Kurt
