Offset Wheels R25/2
Begonnen von Anto, 31 Januar 2019, 12:46:27
Anto
Goodmorning everyone. I'm replacing the spokes of the wheels on the R25 / 2. I would like to know the offset value of the wheel and where to measure it if on the outer edge or on the hub. Thanks and my best regards. Anto
Anto
have a look at
regards Hubi
Anto
Thank you so much. Greetings from Anto
Al Capone
On the forum I found two documents about the offset.
After reading it, I still don't know what it should look like correctly because the information is contradictory.
PDF "Hub offset" for 25 and 25/2 gives the offset of the hub 2mm outside the rim, but I don't know if it's from the drum side or the other side.
The second document shows something else. If I read it correctly, the offset of the hub is 2mm towards the inside of the rim and 5.5mm outside from the brake side.
Can someone dispel my doubts?
1. It is from the drum side.
2. The drawing does not show a wheel! It shows a gauge to proof a wheel (from the drum side ;D).
   - Left side of the gauge is for R25; right side is for R51 - R68.
Al Capone
Hahahaha
Now I know why looking at it for 10 minutes I couldn't understand what the author meant.
This drawing did not represent a circle in any way.
Thank you very much :thumbup:  :respekt:
