Chick starter
Begonnen von Anto, 24 Oktober 2020, 15:52:10
Anto
Hello everyone, is there anyone who can explain to me why every now and then the chick starter pedal gets stuck on top and doesn't want to get off? After a few empirical attempts it ends and everything returns to normal. Thank you
Anto
Anto
I forgot, it is an r25 / 2
Hi Anto,
the first two teeth of the kick starter crescent pinion are worn out. A solution is to pull the clutch lever if you want to kick..... or change the crescent pinion on the kick start lever in the gear box. Not very bad problem but annoying.
Anto
Thanks for your kind response. You mean piece 80 right? Hello and cordial greetings from Antonio
Anto
Grazie 1000, molto gentile
Hi Anto,
as Heiko said: don't worry about it. It is nothing serious. I've got the same phenomenon for the last decades...
Greetings to Calabria,
Anto
Hei Jan, thanks for the advice and for the greetings to my beautiful land. Hello and best regards from Antonio
