Carburator BMW R26,
Begonnen von Misah, 08 Mai 2015, 14:42:45
Misah
hi,
I was so lucky (?) to find a reserve carb for my r26. My original carb is a 1/26/55 with 11 grams "floater"
the new bought model is a 1/26/55 and is a little better on the throttle slide. so with installing the electronic ignition and several other things the 1/26/55 carb is used.
this carb has a 7 grams  floater. is that ok. what I on info can find is this so.
the machine gets while starting a bit too little fuel.. I read some articles about a little bigger idle jet. has anyone experience with it?
I have to check to the spark for the color, just starting to drive this season.
regards,
marty
1/26/46
1/26/52
1/26/55
Misah
Hi marty,
nessecary to know which jets are inside the carburetor! May be, the ones which are installed are wrong and they should be changed
Misah
hey bernd :)
o, yes o course i checked ant they are standard and for the 2 carbs the same.
regards,
marty
