R27 help#2
Begonnen von fidel_98_99, 16 April 2008, 12:50:42
fidel_98_99
Thank you for your help in advance.
1)The back fender on the r27 is the same with the r26?
2)How much is the length of the stobelstange on the r27?
fidel_98_99
Hi fidel,
I think the dimensions of the fenders are the same but the two supports are different. One has tubes and the other only flat material. But which one, I don't know.
Greetings
the tube ones are for the Boxer, if you get an early R 26 fender the holes for the Eber tail light will not fit for the drum tail light of the R 27! The other dimensions are the same!
tassilo (inkognito)
Hello fidel.
Please have a look at the tabular overview (available in English and Dutch as well, just follow the flags in the left upper corner)...the rod's end of the flip part is different between the two models (R26 and R27).
Best regards, Tas
PS: Regarding the valve push rods (Stößelstangen) I have currently no information...
Ad 2.
The length of the pushrods (Stößelstange) is: 173 mm
Btw... Tas! ;D Wouldn't it be an idea to put these lengths in your tabular overview ?
tassilo (inkognito)
Hello Rütz.
Thanks for the link...this is indeed something that should no longer be missing...I will add it tonight  :schrauber:
Best regards, Tas
Hi everyone.
As promised...the values for the valve push rods are now part of the table...
Best regards, Tas
