1958 R26 gearbox (what a journey)
Begonnen von bwprice100, 21 Mai 2016, 17:23:49
bwprice100
I seem to have finally got got the gearbox for my 1958 R26 together.
It now goes through all the gears an the neutral switch works.
I was a really fiddly job but got there in the end and learnt a lot. Hopefully it will be good under power.
Some photos:
https://goo.gl/photos/83YoYpaH2eXkb5aa9
Brian
bwprice100
Herculestom
Hi Brian,
fine job. Congratulations! Very nice photo documentation of the work done. I have seen one thing you did which I missed to do on my gearbox, to measure the function of the neutral switch before and after repair. I was very lucky. It worked. If it doesn't and you want the switch to work there is no way around opening the gearbox again.
Regards from cold South Africa
Tom
umuntu ngumuntu ngabantu
bwprice100
Thanks Tom
It took me a few goes to get it right.
I'm sure a modification could be easily done that would allow adjustment from the outside.
www.eBolt.co.uk www.TooolroomChucks.co.uk
Adjustment of the "neutral switch" can´t be done without openig the gear-box-lid. But it can easily be done before the shafts are setted! After the shafts are inside the gear-box the lid must be heated up to get it off.
bwprice100
Yes I know that but I a better design could be produced that would allow the tang of the neutral switch to be adjusted externally.
Brian
Herculestom
bwprice100
I have a spare gearbox, so I might have a look. :)
One of my problems is I want to redesign the world. :)
