BMW R26 wiring diagram in english language
Begonnen von Karl, 30 September 2012, 14:31:33
Hi allerseits,
anbei eine Anfrage aus England. Kann jemand helfen?
Hello there
My father in South Africa is desperate to locate an ENGLISH wiring diagram for a BMW R26 with a voltage regulator. He has tried, without any luck, to obtain one and has asked me to contact yourselves to see if you could help.
I'd be very grateful if you could be of any assistance.
Many thanks,
Claire Napier
clairenapier [at] mac.com, Surrey, England
DanMay
Try here:
It is more for the /2 twins, but it does have some information about the singles.
/Daniel
ackirafz
Zitat von: DanMay am 30 September 2012, 14:44:50
Try here:
/Daniel
Hallo Daniel
Gibts diese ausführliche Anleitung auch in Deutsch?
Besten Dank und noch einen schönen Sonntag
Gruss Aschi
Gesetz der Schwergänigkeit:
Wenn etwas klemmt - wende Gewalt an. Wenn es kaputt geht, hätte es sowieso erneuert werden müssen.....
Wenn Motorradfahren Arbeit wäre, würden wir das auch noch auf uns nehmen.
Kurt in S.A.
The book mentioned by Daniel is Ver 1.0.  There's a much better version, in color, and has all the singles listed in it.  I got mine from Vech in Mississippi.  I'm glad I got it.
Kurt
Kurt in S.A.
@ Kurt: do you know if this book is available as a pdf?
Kurt in S.A.
Not that I know of.  When it becomes outdated, it will be...just like the other PDF version mentioned above.  But this newer version is so good, I'm not sure if it needs much updating.
Kurt
Kurt in S.A.
