Ls 200 18'' wheel hub question
Begonnen von gordinir8, 26 Juni 2012, 11:31:25
gordinir8
So i disassembly the wheel hub to change bearings etc. I found inside a tube which looks like a spacer between the two bearings, an extra 9.5cm tube that converts the 25 bearing diameter to 22 shaft diameter (I guess this is home made mode instead of the two bushings), the bearings and the dust covers. The big question is if I can use modern rubber seals instead the dust covers and dust gaskets that original has.
gordinir8
