TERMINE und FORUMSTECHNIK => International discussion forum in english language => Thema gestartet von: Pederkr am 20 Mai 2019, 09:56:20
Hi
As some of you looked at Nordtreff, my rebuilt ignition switch is this model. Price-wise a good solution and mechanically functioning. Can be customized 25/3 - 26 - 27 without any problems. However, it requires that the bushing for the lock cylinder on the original model be twisted out of the lamp housing and 3 holes must be drilled
Key is purchased separately.
All wires are assembled with plugs in the ignition switch.
https://www.ost2rad.de/MZ-Ersatzteile/Elektrik-Leuchten-Batterien/Zuendlichtschalter--Zuendschloss-ETZ.html
and key
https://www.ost2rad.de/MZ-Ersatzteile/Elektrik-Leuchten-Batterien/Zuendschluessel-MZ---TS.html
:applaus:
Tolle Idee. Sind alle Funktionen da? wie zB Standlicht?
PS: Da ich weiß das du deutsch sprichst, schreib ich auch einfach deutsch ;-)
Zitat von: Anulu am 20 Mai 2019, 10:37:51
:applaus:
Alles funktioner sind da. Deutsch natürlich schreiben. :worthy:
Pictures of the fitting. Looks nice when the chrome part are in place
sehr sehr tolle Alternative! :applaus:
that's a very good idea. I have not thought that it will fit this way with the chrome cab seeing nothing from the screws.
Hallo Peder,
it looks like you can access the points for cleaning from the underside, also the brass-ears for e.g. rebending, if required.
Is this the case, can you see the points move/touching the ears (from below) when you turn the knob ?
Cheers,
Zitat von: 4Taktix am 20 Mai 2019, 14:40:41
Hallo Peder,
Cheers,
Hello Sascha
No nothing vissble all in a closed environment.
Peder
Genau ;D
Grüss Peder
;D :thumbsup:
Late to the thread, but nonetheless, that ignition lock looks very convincing.
How about the key positions and can you pull-off the key in parking light position?
Hi there. When you turn the key to the left 1. possision is ignition 2. possision is parking light and 3 possision is driving light. To the right 1 possision parking light whit the option to move the key and 2. possision was used by MZ to be able to push start your engine whit a flat battery. I have not used this possision.
Peder
