Lamp..what to order from dealer?
Begonnen von Ziggy Kroatien, 15 März 2009, 11:58:09
Ziggy Kroatien
Again...about the front lamp /2...
This is a original lamp, but unfortunately I don't have ignition lock with el.contact plate.I will order complete plate but there is missing part that hold on altogether.Like i see on dealer's catalogue they don't have this part .
Please if somebody have any kind of image, maybe can help me...
Thanks in advance.
Something miss on this broken pins..
Ziggy Kroatien
Hi again,
it looks like somebody drilled a larger hole in your lamp for an other ignition lock/plate. It seems to be for a "Hella-ignition lock" (original: Bosch)
I don´t think you will going to be able to place an original Bosch-lock here without welding the whole hole. The diameter of the Bosch-lock was much smaller than the one you have right now.
Can anybody help and make a picture of an original /2 lamp/lock?
Pozdrav,
YES WE CAN  ;D
So here we have two older pictures of my /2 frontlight. The el. contact plate is already dismantled.
Hope they help you a little bit. But as Karl said before: Think it'll be quite dificult to find the missing holder for the plate. In IF you find one I think it would be dificult to welt it in the lamp. Maybe it's easier and in the end cheaper to buy a complet lamp with contact plate etc. over ebay than buying singleparts at dealers and ...
Well, your desicion :-)
Greetings.
Ziggy Kroatien
Thanks guys..I know now next step.Weld..then make a holder..
:respekt:
