R20 main light
Begonnen von Antony, 20 Juni 2022, 20:18:39
Antony
Hello,what is right specification of main light for BMW R20/1937 ?
Is it Bosch EAS150?
Thanks
Antony
Hello Anthony.
You are right, it's a Bosch EAS 150 2 T 45 head light.
All the best, Taz
Northumberland (2024)
Antony
Thanks, ...and any advice(where to find) about wiring diagram for R 20?
...and what about lightening of speedometer R20 ? Was it part of electro instalation or not?
Sorry, I haven't any direct answers to those...there is a source in Germany (currently sold out, but there's hope, I guess): https://emw-oldtimer.de/Kabelbaum-ohne-Bremslicht-mit-Schaltplan-fuer-BMW-R20-R23 where you can get the wiring harness incl. the diagram...this should answer the speedo light question as well.
@Borgward kannst Du evtl helfen?
cwf
If you join the Veteran BMW Owners of America (£30 per annum digital membership from July 1st) they have an excellent library on line and a great archive of magazines.
Charlie.
sorry - I'm just on a windsurfing vacation ...
have a look at the R23 handbook - there you can find a wiring diagram which is also valid for the R20
good luck
correction: the wiring diagram can be found in the document
as far as I remember (I'm about 4000km away from my R23) there is no special light bulb for the speedo - it is lightened indirectely by the parking light bulb
cheers Hubi
i don'T know exactly the R 20-----but for the most prerwar machines there is only a cut - off in the refelector which illuminates indirektly the odometer ( which has a cut off too)
yep, that's the way it is 8)
