Headlight identification - R26?
Begonnen von bwprice100, 11 Januar 2015, 20:02:10
bwprice100
Hi all I wonder if some of you can help identify the two headlight shells in the following pictures.
https://plus.google.com/photos/109706988765584743320/albums/6103143525392919729
The black one is, I pretty certain off an R26 but I need to know if some of the smaller holes are extras someone has added.
The grey coloured one came with a Bosch lamp assembly and is slightly larger than the black one. It also does not have the scallop on the underside like the black one but I am not sure what bike it is for.
On some of the parts list I have looked at there is a Bosch headlight and a Hella headlight shown as options for the R26 bikes.
Any help much appreciated.
Brian
bwprice100
The black one is from a 25/3 (dent underside of the shell)...the small holes are extra added
the grey one is pre-war (with 2 extra holes ;D)....the exact diameter was interesting....so ist seems R12 with battery ignition....late fabrication ("normal" odometer...the first have a "Walzentacho")
bwprice100
Thanks for that rolf
I have added two more photos showing diameter, the black on is 7 1/4" and the grey one is 7 1/2"
I was hoping they were for my R26.
Brian
If your R 26 is not a R 12 or a R 25/3 (as I wrote above)....none of them were original for the 26....but you can take the 25/3 shell...it is nearly the same...or you find someone who will change it with a shell without dent (they are more on the market than these with dent)
bwprice100
Thanks rolf
Brian
PS
sell the r12 Shell....you get more than you have to pay for a 26 shell
bwprice100
Sounds like a plan. :)
Thanks for your help.
Brian
Please, what is the shell ?
My english is so small.
Probably in german.
Gruß mek  ::)
Shell gleich Lampentopf...oder wolltest du wissen was ich geschrieben habe?
bwprice100
Probably in german.
Gruß mek  ::)
Was haben Sie überlassen, sobald Sie Sie bolid Ei, eine Schale gegessen haben
Google German :)
bwprice100
I have added a couple more pictures of the R12 headlight showing the Bosch glass, chrome bezel and reflector fitted.
I am now open to offers.  :)
