Rattling sound with increasing rpm
Begonnen von euro518, 06 Juni 2016, 19:04:28
euro518
Hello all. I thought I would pose a question to the group regarding a noise that I hear when my R26 engine revs up. At idle or when lopping along all is fine. However, when I increase the revs a rattling sound comes from the area of the engine. Eventually it mellows out at a higher rpm. The engine was overhauled a few years back and has good compression and otherwise runs well. It's not a lower end noise. Could vibration through the exhaust header, pipe and muffler make this noise?
Kevin
euro518
Of course,
but please make a record and load it up.
Thanks
euro518
Ok. I will try to do it. I am away from home for a bit and will do it when I return.
Kevin
Is it just in neutral or also during load whilst driving?
gordinir8
I hope this is not the case but here is my story. I had a noise also while rev up and eventually was a failed con rod. I had any 8000 kms after overhaul unfortunately when i was discover what it was, damage was very big so just in case check that also and maybe drain the oil to see if any metal particles are in.
Similar topics (2)
