Suddenly no spark.
Begonnen von Studsgaard, 25 April 2017, 14:37:34
Studsgaard
Nice Rolf! I ment the distance from the tip of the finger moving the rocker to the palm resting on the engine case - Point taken' though.
The contact breaker didn't look greasy or dirty but I gave it a good clean with break cleaner as instructed by you. I had a play with the screw and couldn't get ground contact. To me it looks like the 3 discs are there but maybe could do with a dismantle and cleaning up? I could also disconnect both wires of the coil and measure it again if you suspect an intermittent failure of this.
Studsgaard
I(!) would look if there are the 3 slices....it seems that your lower pertinax slice has a distance to the metal contact breaker holder. Have you looked at he painting in the other Threat?
Zitat von: Borgward am 26 April 2017, 17:55:26
Heiko, you are right, there are some symptoms for a faulty battery . But is this the only explaination for the engine breakdown?  ???
Klar... could be. If there is a short circuit in the battery the current raises up und the voltage collapses so that there is no voltage at all on the engine.
.. but then the red light would not lit  ;D
Studsgaard
Very nice drawing skills Rolf!
I wasn't able to detect any 'falls ground' through the assembly. I could disassemble, clean and assemble some time next week if you think the fault lies here.
If number 2 wasn't at his place....you (can) get though the screw ground
Right.... that's blöd.  ::) i forgot.... sorry for that shit in this case.
