r27 help
Begonnen von fidel_98_99, 04 März 2008, 10:47:07
fidel_98_99
i am restoring a R27.
That part is missing.
It is referred as :Federscheibe.
what is that? A simple washer?
The r27 had a kettenspanner or it is extra?
Thanks
fidel_98_99
Hi fidel,
the "Federscheibe" is not a simple washer but a ring made out of special steel and a wavied outer contour to allow a specified pressure in axial direction.
The Kettenspanner was equipped since # 378 395. It was always recommended by BMW and others that it is useful to install this part on older ones. If installed, a longer chain has to be used (code "blau" # 11 32 0 032 550)
Cheers
