Sandblasting cylinder and cylinder head
Begonnen von Dan, 16 Januar 2007, 12:44:41
Dan
Hello
Im new to this forum.
I wants to sandblast my cylinder and cylinder head of my R25. I know that sandblasting does not effect metal, but isn´t it neccesary to protect the indside of the cylinder, and the valve seating from the sand??
Thanks in advance
Dan
Hallo Newby,
even glass-pearl blasting would effect metal.
I would only take glass-pearls for blasting.
The head could blasted without protection..but with valve covers (to prevent extreme blasting the valve-guides)....but afterwards completely dismantled and cleaned. It makes sense , because at this time you have to regrind the valve-seats. they are not destroyed from blasting... after every dismantling it is senseful to do this job.
The cylinder must be covered at the piston boring. Take "Tesa-Krepp" and on this thick grease.
Dan
Hallo
I have read some of the text in Instandsetzungsanleitung at this site, so yes I would regrind the valve seats afterwards.
Tesa-Krepp and grease sounds good and easy to do!
Thanks for the anwers
Dan
Hello again
I forgot to ask wich black paint should I use to afterwards??
Dan
