Thread size - AM4x8?
Begonnen von Dave, 07 Oktober 2005, 04:09:06
Dave
ahh more questions...
See attached picture, unfortunately the tank has had a bump and the previous owner used body filler to fix the dent. In doing so he filled in the emblem mounting holes!! :kopfhau:
My plan is to use a tap drill to remove most the filler then run the appropriate tap into the hole.
The Parts Catalogue PDF from here suggest a M4x8 screw which is easy but the BMW Mobile Tradition electronic parts catalogue states that the screw is an AM4x8.
My question is I have never seen the "AM" prefix to a screw size, any thoughts as to what the "A" stands for?
Thanks, Dave.
Dave
Kiwi-Kai
Hi Dave
It is a CSK head (with a rounded head!), 8 mm long brass screw - M4 / pitch 0.7
AM????? A = alt (old) don't know maybe a printing error  ;D
Kai
don´t know it exactly, but i think, BMW used a different headtype with another diameter of the head in the 50´s and 60´s... :-\\
Maybe Rolf knows the answer... Rolf: Help!  ::)
Heiko "U(nsafe")  ;D
Kiwi-Kai
Hi Dave,
Are u from Oz or what??????? Round the corner ;D
Kai Kiwi
Sorry, I also don't know the function of "A", maybe a (new) internal sign for "dull-plated"?
Or really a printing error.
Rolf H(elpless)
Dave
Thanks chaps,
I ran the tap drill for an M4 thread and then used a bottoming tap to clear the threads. All worked perfectly, as Rolf suggested the "A" prefix is a modern thing I suspect.
Kai, yep. I'm up in sunny Brisbane. Please send rain :)
Cheers, Dave.
